Thread: Reload All Xrefs
    2010-11
    3
    Default Reload All Xrefs
    I did this several years ago on an older machine I had. My internet search doesn't seem to be turning up answers. All the feedback I'm getting says:
    Reload All Xrefs Macro:
    -xref; reload; *;
    however my machine is not understanding "*" as a select all macro, or as a name at all. any help with this?
    2003-03
    Philadelphia, PA
    2,390
    Default Re: Reload All Xrefs
    Quote Originally Posted by tsherman698 View Post
    -xref; reload; *;
    What kind of feedback are you getting at the Command: line? You do not say how you are implementing this macro (menu item, script file, etc.), but my guess is that you do not want to have both the semi-colon and the space between items, if the method you are using supports either as being the same as pressing the "Enter" key. I tried this as a simple, one-line SCRIPT file, and a single space between items and one after the asterisk at the end had it working just fine in AutoCAD Architecture 2014.
    2013-12
    5
    I use a similar LISP file with no problems - maybe try using this:
    (defun c:XE()
    (command "-xref" "RELOAD" "*" )
    (princ))
  1. Reload xrefs, but only loaded.
    By Arterius in forum AutoLISP
    Last Post: 2015-09-21, 12:37 PM
  2. Replies: 11
    Last Post: 2010-04-08, 09:03 PM
  3. Replies: 0
    Last Post: 2009-01-31, 04:01 PM
  4. Automatically reload changed xrefs
    Last Post: 2006-03-26, 09:11 PM
  5. Automatically reload XREFS
    Last Post: 2006-02-08, 11:32 PM
Tags for this Thread
