Is there a way to add custom fields to the Rename and Renumber Dialog box in the Sheet Set Manager? I have generated custom fields for a Sheet Count system, so that I can enter in the Total Number of Sheets in a Set in the Sheet Set Properties and also enter in the Particular Sheet Count for each Sheet in that Set. My only problem is that I would like to quickly update the Sheet Count of each Sheet by using the Rename and Renumber Dialog box. This would be similar to the way you might Rename Sheet "A-1" to "A-2" without having to open each file. Hope I am being clear enough. Any suggestions? See the attached images for reference.
