Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 27
Thread: Find and Replace is NOT "Replacing" but adding to it??
  1. #11
    2009-11
    5,517
    Default Re: Find and Replace is NOT "Replacing" but adding to it??
    Yes you are mistaken, and you're forgiven
    I have a drawing (or two) that have section views, with elevation tags (in the form of blocks with attributes) which have different elevation values and some text.
    I want to "find" all the various elevations and replace them with SEE PLAN.
    I have done this before and it should work with an asterisk wild-card, I wasn't sure if there's a bug in 2013 as Cadtag mentioned.
    ....Ohhhhhhhhhh, I can haz understand now (it's been a particularly hard week here).
    I'll Post back as soon as work permits, but thanks for your patience while I catch up.
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  2. #12
    2009-11
    5,517
    Could you post a sample drawing?
    Computer Specs:
  3. #13
    2005-06
    in the upper right corner
    3,180
    Quote Originally Posted by BlackBox View Post
    Sure, here's a dumbed down version, thanks.
    Ted
    ____________________________________________________________________ ________________
    Windows 7 Professional
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
  4. #14
    2009-11
    5,517
    Sorry, I'm really short on time right now... So this brute-force sample will have to do for now (undo supported)... I'll come back to refine it later.
    HTH
    (vl-load-com)
    (defun c:FIND+ (/ *error* _ReplaceString pattern newString acDoc oBlocks
                  objectName blockDef
      (defun *error* (msg)
        (if acDoc
          (vla-endundomark acDoc)
        (cond ((not msg))                                                   ; Normal exit
              ((member msg '("Function cancelled" "quit / exit abort")))    ; <esc> or (quit)
              ((princ (strcat "\n** Error: " msg " ** ")))                  ; Fatal error, display it
        (princ)
      (defun _ReplaceString (obj)
        (if (wcmatch (vla-get-textstring obj) pattern)
          (vla-put-textstring obj newString)
      (if
        (and
          (setq pattern
                 (getstring T "\nEnter string pattern to search for: ")
          (setq newString (getstring T "\nEnter new string: "))
         (progn
           (vla-startundomark
             (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
           (setq oBlocks (vla-get-blocks acDoc))
           (foreach y '(modelspace paperspace)
             (vlax-for x (vlax-get acDoc y)
               (cond
                 ((= "AcDbBlockReference"
                     (setq objectName (vla-get-objectname x))
                  (if (and (= "AcDbBlockReference" (vla-get-objectname x))
                           (= :vlax-true (vla-get-hasattributes x))
                           (setq blockDef (vla-item oBlocks
                                                    (vla-get-effectivename x)
                    (foreach att (vlax-invoke x 'getattributes)
                      (vlax-for item blockDef
                        (if (= "AcDbAttributeDefinition"
                               (vla-get-objectname item)
                          (progn
                            (if (= (vla-get-tagstring att)
                                   (vla-get-tagstring item)
                              (_ReplaceString att)
                 ((wcmatch objectName "AcDbMText,AcDbText")
                  (_ReplaceString x)
      (*error* nil)
    ... Example from command line:
    Command: find+
    Enter string pattern to search for: EL. *
    Enter new string: EL. SEE PLAN
    Command:
    Computer Specs:
  5. #15
    2015-11
    22
    2
    While BlackBox's code skills are impressive, for those that don't want to mess with a lisp routine and use the built-in find/replace...
    Thought I would post something mildly helpful for my first post...
    It is not a bug. The reason that the wild card isn't working, is that there is no "end" to the search string.
    For example, if you had a mtext paragraph (or line of text for that matter) that stated:
    "...blah, blah blah modEL. some more text etc, etc...."
    the EL. * replace would overwrite EVERYTHING after [modEL. ] even if what followed happened to be hundreds of characters long, and we don't want it to work like that (except in the OP's specific case for this specific drawing that doesn't have any other occurrence of "EL. ")
    To find/replace the elevation instead of adding to the string:
    Find: EL. *" <---(add the inch mark to give the wild card and "ending")
    Replace: EL. SEE PLAN
    (Found text = EL. 100'-0" , Modified text = EL. SEE PLAN)
    So to clarify; in the EL.[space][wildcard] search, the [wildcard] isn't really doing anything, but adding the inch mark - EL.[space][wildcard]["] - finds strings that adhere to EL. *[whatever is here]".
    Hope that makes sense..
  6. #16
    2005-06
    3,180
    Quote Originally Posted by reidcharley View Post
    First of all.... Welcome to AUGI and congrats on your first post!
    Second of all.. HOLY CR@P!, thanks!
    Is this a new thing?
    I have done this lots and lots of times before with a simple "*" wild-card and it has worked well, at least with lower versions of AutoCAD.
    According to 'HELP the asterisk is supposed to match any string, so it's assumed that (EL. *) would be selecting and replacing everything after EL.<space>.
    Is there anywhere this is documented so I/we can find out more?
    Thanks.
    Ted
  7. #17
    2009-11
    5,517
    That is kind of you to say, reidcharley... In deed, welcome to AUGI, and congrats on your first post!
    Hoping that I had simply been overlooking the built-in functionality, I tried it (your suggestion of EL. *") on the sample drawing tedg uploaded here, and I was unsuccessful (see pics attached)... What version(s) are you using that this methodology is successful?
    Cheers
    Computer Specs:
  8. #18
    2005-06
    3,180
    Cheers
    Hey BB,
    I tried it this morning and it worked for me, that's why I was so excited.
    I'm using AutoCAD 2013 (fwiw)
    I'll try it again on some other examples..
    *EDIT tried it on the sample drawing I posted yesterday, worked great for me (see screen shot).
    Ted
  9. #19
    2009-11
    5,517
    Hey BB,
    No worries; it must have been an enhancement in 2013, as the screenshots I posted were from your sample drawing in 2012... Either way, I'm glad you got it sorted, and kudos to reidcharley.
    Computer Specs:
  10. #20
    Cairo - no, not Illinois
    4,753
    Thanks -- that makes sense.
    I'll cordially disagree though, with the statement that it's not a bug. It may be working as designed, but it's still a bug inasmuch as it does NOT work as expected, nor is it consistent with other uses of the '*' as a wildcard character that I've encountered in 30 years. Invariably the * has meant 'from here on to the end'. that end may be a 'end of line', end of string, or a predefined delimiter (eg the period in a dos filename).
    so: "the EL. * replace would overwrite EVERYTHING after [modEL. ] even if what followed happened to be hundreds of characters long, and we don't want it to work like that "
    is incorrect -- as I _do_ want and expect it to work like that. I can see advantages to having an ending character, but in the case of No Ending Character being supplied, the asterix should be a wcmatch the remainder of the string.
  1. AutoLisp to use "Find & replace"?
    By tmad101185 in forum AutoLISP
    Last Post: 2011-03-23, 12:36 PM
  2. Replies: 9
    Last Post: 2009-09-09, 07:43 AM
  3. Replacing "laymrg" in Acad2006 with own code
    By nojunk217 in forum AutoLISP
    Last Post: 2009-02-04, 07:55 PM
  4. Replies: 3
    Last Post: 2008-10-04, 12:15 PM
  5. Change Find and Replace "Zoom To" height
    By JeremiahM in forum AutoCAD General
    Last Post: 2007-06-04, 03:09 PM
Tags for this Thread
