Thread: clipping viewport problems
    2003-06
    5
    Default clipping viewport problems
    So, I go in and create a view port. Then I clip it to what I need. The parts that I don't want still show up after I freeze the layer. I then made a polygonal view port and the same thing happens. Am I missing something here? I did the search thing in the forums and nothing, so any help would be nice.
    2005-06
    in the upper right corner
    3,507
    Default Re: clipping viewport problems
    Quote Originally Posted by draftermad View Post
    As far as I know you can't freeze the layer the clipped viewport is on, or else it looses it's ability to "clip".
    If you don't want it to plot, you need to put it on a "No Plot" layer.
    Suggested NCS layer would be G-ANNO-NPLT and make sure you have plotting turned off.
    HTH
    2003-06
    5
    I just seen another thread about this and turning the layer off works. Still the polygonal view port should have worked the same as any normal view port.
    2005-06
    3,507
    I'm assuming you have a viewport that is something other than a recangle correct.. and that is why you "clipped" it?
    Because if you use just the "mview" command and make an OOTB rectangular viewport, you can freeze that layer.
    But you probably know that, right?
    Just throwing it out there.
  1. Viewport Clipping Planes
    By stusic in forum 3ds Max - General
    Last Post: 2009-07-23, 07:45 PM
  2. Viewport Specific 3D Clipping Box
    Last Post: 2007-07-10, 04:19 PM
  3. Can't seem to turn off viewport clipping
    By shawn.bean in forum AutoCAD General
    Last Post: 2007-04-18, 03:21 PM
  4. Replies: 2
    Last Post: 2006-06-16, 07:06 AM
  5. Viewport clipping issue
    By Spectrefish in forum AutoCAD General
    Last Post: 2004-09-30, 07:51 AM
