Results 1 to 8 of 8
Thread: Autocad 2004 - Insert a "Custom Property" in the drawing ?
    2008-04
    St-Ferdinand, Québec
    141
    Default Autocad 2004 - Insert a "Custom Property" in the drawing ?
    Hi !
    In the past, I used Autocad Arch 2011 and I do what I want easily...
    But for the now, with Autocad 2004, I can't add a Custom Property (dwgprops)...
    Is someone can help me ? Thanks in advance !
    2008-04
    141
    Unhappy Re: Autocad 2004 - Insert a "Custom Property" in the drawing ?
    Hi !
    Maybe my question is not really clear...
    I created in the "DWGPROPS" a Custom Property named APPT...
    Is there a way to display her value in a TEXT or MTEXT wherever in the drawing ?
    Thanks in advance !
    Tallahassee, FL USA
    3,550
    Default Re: Autocad 2004 - Insert a "Custom Property" in the drawing ?
    No, that would require a "field" which didn't exist back then as far as I can remember.
    2008-04
    141
    Is there another way, maybe with LISP ???
    Thanks in advance !
    Cairo - no, not Illinois
    4,964
    It's probably possible with LISP - not having access to 2004 I can't walk you through it, and the method of storing and accessing dwgprops data has changed over the years. But LISP would not be 'live', it would just create a static text element that showed a constant value -- at that point you might as well just put it in as text.
    Maybe look into RTEXT?
    2008-04
    141
    Hi, if I really understand, as soon as my custom property (APPT) will change, the text will still the same ?
    4,964
    yeah, that's about the size of it. LISP can read the value, and write the Text, but it's not a substitute for a FIELD object. Once the Text is created, either by LISP or manually, it's just plain old text and won't change until it's edited.
    If the DWGPROPS values in 2004 can be read with DIESEL, the ExpressTool RTEXT would be a possibility, although I think that would only update on a drawing open action. I'm not sure about that, since I've no need to use RTEXT.
    Bascially, if you are going to change the custom property and want it reflected in the drawing, you need to upgrade - and since the only upgrade option is 2014, that's a full cost expenditure.
    If your organization is unwilling to spend that, then perhaps they should look into BricsCAD from Bricsys,or Ares Commander from Graebert systems. More functionality than 2004, and a lot cheaper than a new Acad seat. (You can try out a free (and somewhat limited) version of Ares by downloading the Draftsight application. That version does not do LISP, but for basic drafting it works well.
    2008-04
    141
    Finally, RTEXT do what I want, with a Diesel Expression like: $(getprop, %APPT)
    Thanks for this suggestion !
  1. insert "barcode" to drawing
    By yeun in forum Facilities Management In Practice
    Last Post: 2012-11-20, 04:38 AM
  2. if filter text equals "*" insert block "*"
    By d_m_hopper in forum AutoLISP
    Last Post: 2009-04-24, 05:46 PM
  3. tipos de Hatch "Custom" vacios en el Autocad 2008
    By cadia in forum Español - AutoCAD / AutoCAD LT
    Last Post: 2008-06-08, 01:29 AM
  4. Replies: 8
    Last Post: 2007-04-04, 12:39 PM
  5. AutoCAD 2007 ignoring "Start In" shortcut property
    By sthedens in forum AutoCAD General
    Last Post: 2007-01-29, 03:44 PM
