Thread: TIF file too large and crashes when I connect
    2013-09
    Default TIF file too large and crashes when I connect
    I have a client who sent me a very large TIF file which I am assuming has LiDAR data - 4.5GB of the whole campus. When I try to connect to the file, Map3D crashes on me every time. What can I do to connect to the file? Is there a good way to compress or subdivide the file? What is the largest file size Map3D can support? I am using Map3D 2014. My system uses Intel Core i7, has 32GB RAM and 64-bit operating system.
    2002-07
    Default Re: TIF file too large and crashes when I connect
    capeziosa:
    Have you resolved this issue - I was browsing for a solution and saw your question had no replies - I had trouble loading 9GB of Tiff tiles some years ago - but the current machines like you describe should have no problems. If it is still a problem - do you have the associated .tfw files - and how are you connecting ?. When I had trouble the Autodesk Subscription Centre were very helpful.
    regards
  1. 2014: Autocad LT crashes when publishing large files
    By Maya61 in forum AutoCAD LT - General
    Last Post: 2014-12-15, 08:29 PM
  2. 2013 Connect Map3D to .GDB File
    By jenniferchavez in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2013-10-07, 11:00 PM
  3. Query shape file connect by FDO
    By Glenn Pope in forum AutoCAD Map 3D - Data Connect (FDO)
    Last Post: 2011-12-01, 12:03 AM
  4. Crashes with large files 2009 Autocad Map
    By drum.cavers in forum AutoCAD General
    Last Post: 2008-12-01, 11:41 PM
  5. Using FDO to access either shape file or connect SDE
    By VBOYAJI in forum AutoCAD Map 3D - General
    Last Post: 2006-08-17, 06:52 PM
