Thread: Update CADmep data for previously modeled components
    Post Update CADmep data for previously modeled components
    We have encountered an issue on a project where the catalogue order numbers for components have changed and we want this to reflect within our model.
    We have changed the field behind the relevant components on the tool palettes and for new components inserted works fine however we cannot get this change to reflect on components already placed within model.
    has anybody encountered this issue before and found a solution?
    cheers
    2013-09
    Seattle / Tacoma, Washington
    13
    Default Re: Update CADmep data for previously modeled components
    If you have design line setup, recreate the run w/design-line.
    Component by component you can swap out the items for like items.
    You can also script updating the properties using the Fabrication scripting language.
  1. 2014: Can Data Links Update Automatically?
    By settel in forum AutoCAD Tables
    Last Post: 2014-08-22, 07:32 AM
  2. 2011 Update Feature class data
    By andreijj250504 in forum AutoCAD Map 3D - General
    Last Post: 2013-03-30, 02:27 PM
  3. Update Data Link Location
    By stusic in forum AutoLISP
    Last Post: 2012-10-31, 08:49 PM
  4. Data Link Update Problems
    By DBill2508 in forum AutoCAD Tables
    Last Post: 2011-10-26, 07:18 PM
  5. Update on an old question - mirror components in schedules
    By angus.110169 in forum Revit Architecture - General
    Last Post: 2010-05-11, 02:03 PM
