Thread: Help with concrete stairs connecting to floors!
    2013-06
    24
    Default Help with concrete stairs connecting to floors!
    I need to connect this monolithic stair to the floors and I'm not sure how to go about doing that. Can you please help? I have attached a screen shot below
    Revit Structure 2012
    2002-09
    Madison, WI
    5,688
    Default Re: Help with concrete stairs connecting to floors!
    In place extrusion is what I'd do. But I'd do that for then entire stair. Mainly cause I don't like the tool. Make them the same material and they should join together.
    2007-01
    226
    Another thing you may need to change is, edit the cast-in-place monolithic properties. change type properties, run type, structural depth.
    change this to make the bottom of stair run thicker as required for stair span. The default out-of-box Revit setting is too thin for any stair span.
    i create all of my c.i.p. stairs as sweeps. that way i can include\edit any landings or thickened slab edges as required.
  1. Concrete stair connecting to beams and walls.
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2015-01-20, 04:08 PM
  2. Concrete Stairs and Floors
    By mmodernc in forum Revit Architecture - General
    Last Post: 2011-09-19, 02:26 AM
  3. stairs show through floors
    By frankie right in forum Revit Architecture - General
    Last Post: 2008-05-03, 03:22 AM
  4. Concrete Framed Floors
    By BunyipCatcher in forum Revit Structure - General
    Last Post: 2006-01-27, 08:53 PM
  5. Pre cast concrete stairs / raised access floors
    By dwiggett1884 in forum Revit Architecture - General
    Last Post: 2004-03-02, 03:41 PM
