Results 1 to 8 of 8
Thread: Installing Design Suite Premium 2014 - wse3.msi
    2001-12
    St. Louis
    5,393
    Default Installing Design Suite Premium 2014 - wse3.msi
    I'm trying to install my design suite. I got an error during the Microsoft WSE 3.0 installation that the feature I'm trying to use is on a network resource that is unavailable. I've manually installed and uninstalled and copied and renamed the wse3.msi multiple times in the specified folder or pointed to other folders, and it's just acting like the file and the program are not there, though I can see it's installed.
    Any tip to somehow get around this?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,393
    Default Re: Installing Design Suite Premium 2014 - wse3.msi
    2013/9/26:09:52:18 mes0945 BJC11179860 === Setup started on BJC11179860 by mes0945 ===
    2013/9/26:09:52:18 mes0945 BJC11179860 Path_Length: 149
    2013/9/26:09:52:18 mes0945 BJC11179860 Current Directory K:
    2013/9/26:09:52:18 mes0945 BJC11179860 Launch
    2013/9/26:09:52:18 mes0945 BJC11179860 CommandLine
    2013/9/26:09:52:18 mes0945 BJC11179860 Setup Windows update reboot is pending
    2013/9/26:09:52:22 mes0945 BJC11179860 Setup Autodesk® Building Design Suite Premium 2014 Will restart automatically.
    2013/9/26:09:52:22 mes0945 BJC11179860 === Setup ended ===
    2013/9/26:10:03:59 mes0945 BJC11179860 === Setup started on BJC11179860 by mes0945 ===
    2013/9/26:10:03:59 mes0945 BJC11179860 Path_Length: 149
    2013/9/26:10:03:59 mes0945 BJC11179860 Current Directory K:
    2013/9/26:10:03:59 mes0945 BJC11179860 Launch
    2013/9/26:10:03:59 mes0945 BJC11179860 CommandLine
    2013/9/26:10:03:59 mes0945 BJC11179860 Current Directory C:\Users\mes0945\AppData\Local\Temp\_AI2BEF.tmp
    2013/9/26:10:06:05 mes0945 BJC11179860 === Setup ended ===
    2013/9/26:10:04:13 mes0945 BJC11179860 === Setup started on BJC11179860 by mes0945 ===
    2013/9/26:10:04:13 mes0945 BJC11179860 Path_Length: 149
    2013/9/26:10:04:13 mes0945 BJC11179860 Current Directory C:\Users\mes0945\AppData\Local\Temp\_AI2BEF.tmp
    2013/9/26:10:04:13 mes0945 BJC11179860 Launch
    2013/9/26:10:04:14 mes0945 BJC11179860 Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\mes0945\AppData\Local\Temp\_AI2BEF.tmp\Setup\RevitSetup.dll
    2013/9/26:10:04:14 mes0945 BJC11179860 Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
    2013/9/26:10:06:05 mes0945 BJC11179860 PageOpen LaunchDialog
    2013/9/26:10:09:34 mes0945 BJC11179860 PageOpen LicenseDialog
    2013/9/26:10:09:36 mes0945 BJC11179860 PageOpen ProductInfoDialog
    2013/9/26:10:24:21 mes0945 BJC11179860 PageOpen ProductSelectionDialog2
    2013/9/26:10:25:22 mes0945 BJC11179860 PageOpen FullProgressDialog
    2013/9/26:10:25:22 mes0945 BJC11179860 Installing DirectX® Runtime: "K:\3rdParty\DirectX\DXSETUP.exe" /silent
    2013/9/26:10:26:16 mes0945 BJC11179860 Install DirectX® Runtime Succeeded
    2013/9/26:10:26:17 mes0945 BJC11179860 Installing Microsoft WSE 3.0: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk® Building Design Suite Premium 2014" SETUP_PACKAGECODE={D7E74739-DCD0-48e4-86A5-6203809C3639} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=".NET Framework Runtime 3.5 SP1,;;;" ADSK_SOURCE_ROOT="K:\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1 TRANSFORMS="C:\Users\mes0945\AppData\Local\Temp\_AI2BEF.tmp\Media.mst"
    2013/9/26:10:49:33 mes0945 BJC11179860 Install Microsoft WSE 3.0 Failed Installation aborted, Result=1612
    2013/9/26:10:49:33 mes0945 BJC11179860 Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    This is the error log. Running Windows 7.
    This post http://forums.autodesk.com/t5/Instal...2996790#M32676 suggests not logging into the domain, but, just the pc... I guess I'll give that a try next.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,393
    Quote Originally Posted by Wanderer View Post
    Okay, with Windows 7, I no longer see the option to log into the pc without logging into our domain.
    I figured the closest I could get was unplugging from the network. Didn't work.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,393
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2001-12
    St. Louis
    5,393
    Autodesk support suggested I run this... http://support.microsoft.com/mats/pr...and_uninstall/ ~shrugs~ I don't know. I was able to manually uninstall and reinstall that program, but, I'm willing to try anything at this point.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,803
    Enter the username as localhost\username
    R.K. McSwain | CAD Panacea |
    2001-12
    St. Louis
    5,393
    R.K. Thanks... I was too busy to google last night . I had a party to get to.
    Turns out, the autodesk advised solution worked just fine! The problem was with MS and was resolved with their tool. Awesome! The install ran while I was out.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Earth
    9,803
    Stupid question, but is your %temp% directory fairly empty?
    I've seen a "full" (however that may be defined) %temp% directory cause all sorts of problems.
    Switching to a different account (local admin vs. your domain acct) would "fix" this, assuming the other accounts %temp% directory was mostly empty...
    just a wild guess....
    [EDIT] - ok, I see you got it now. so....nevermind.....
  1. 2015: Building Design Suite Premium Available for Download
    By Dean Camlin in forum Revit Architecture - General
    Last Post: 2014-04-14, 08:47 PM
  2. Inventor Product Design Suite Premium 2013
    By jimmy.long in forum CAD Management - General
    Last Post: 2013-06-24, 03:16 PM
  3. 2014: Building Design Suite - Premium 2014 activation error / problem
    By wboyanton in forum AMEP General
    Last Post: 2013-05-03, 04:14 PM
  4. Replies: 2
    Last Post: 2013-04-30, 12:44 PM
  5. Replies: 0
    Last Post: 2012-11-28, 09:25 AM
