Thread: Lidar data- I dont want everything
    2003-01
    Denver, Colorado
    199
    Default Lidar data- I dont want everything
    I am working with Lidar points. When I create a surface from the point cloud, it is selecting everything. buildings, trees, etc.. How do i get it to just use the ground points in the lidar data?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Default Re: Lidar data- I dont want everything
    Is there anyway to isolate the ground points within the lidar data?
    I do not know of any way to only select the ground points. If you have a known range of elevations, you could limit your surface to fall within that range.
    2008-07
    4
    Hi Opie, are you using the point cloud style dialogue and setting the classification to ground? Then in the points tab, set assign color by classification - I was under the impression this filters out all but the selected classification, then when I create a surface from it we have bare earth topo. Is this not correct? If there is no function to filter out the classifications I need then I'm afraid I won't find it very useful at all.
  1. Replies: 0
    Last Post: 2014-12-17, 10:53 PM
  2. CV318-4: Connecting the Dots: Creating AutoCAD Civil 3D Surfaces with LIDAR Data
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:38 AM
  3. GS9300-1: Using AutoCAD Map 3D and LiDAR Data to Enhance 3D Maps and Designs
    By Autodesk University in forum Planning and GIS
    Last Post: 2014-12-01, 03:31 AM
  4. LiDAR Data Support
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2012-08-02, 07:31 AM
  5. Lidar file format
    By jenniferchavez in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-02-24, 10:59 PM
