Thread: Spiral Stairs
    2009-09
    New York, New York
    80
    Default Spiral Stairs
    Sorry for basic question;
    How does one control the tread depth of a spiral stair?
    Right now I have minimum tread depth set to 2" (tiny, depth is measured in the center), but the depth does not change:
    When I "edit stair" and reduce the radius, the depth does not change and the treads rotate, reducing the head room.
    The little blue arrows at the end of the first and last tread are not helping with this, they only rotate the entire stair. I suspect I am not using them correctly or the depth is locked somehow. Is there an easy solution?
    Sorry if this is obvious....
    2009-09
    New York, New York
    80
    Default Re: Spiral Stairs
    Got it! - "Actual Tread Depth" can be easily adjusted in the properties box.
    Is it possible for me to delete my own thread after posting? Right now that would be useful.....
    2003-03
    Philadelphia, PA
    2,392
    Quote Originally Posted by BillB_UH92 View Post
    Thanks for posting back with the solution. Keeping this thread here will help others with the same question.
  1. Spiral Stairs
    By warnoe uk in forum Style Management
    Last Post: 2018-11-14, 01:18 PM
  2. Spiral stairs - A Helix story
    By brad.67018 in forum AutoCAD Gallery
    Last Post: 2013-06-27, 07:51 AM
  3. Curved and spiraling wall along spiral stairs
    By eah4u in forum Revit Architecture - General
    Last Post: 2009-03-25, 02:22 PM
  4. Spiral Stairs
    By Steve_Stafford in forum Revit Architecture - General
    Last Post: 2008-09-06, 03:14 PM
  5. SPIRAL STAIRS
    By gaelbillot in forum Revit Architecture - General
    Last Post: 2008-06-01, 09:34 PM
