Thread: Frit Glass not not showing a shadow pattern in render?!?!
    2013-09
    Default Frit Glass not not showing a shadow pattern in render?!?!
    Hello,
    I created a custom frit pattern material which I want to use in my curtain wall panel. I modified an existing opaque glass panel by using the "cutout" in material appearance tab and uploaded my own image. This created the disired appearance on the glass panels. The problem is that the opaque portion of the glass is not creating a shadow when rendering. You should be seeing stripes of shadow but instead the glass renders as all clear. Can any help, I havent been able to get very far with other threads. Image attached. Also using Revit 2014. Thanks!MWA_D_2014.jpg
    2001-07
    Phoenix, AZ
    1,003
    Default Re: Frit Glass not not showing a shadow pattern in render?!?!
    To be clear, the image you posted is a live, shaded, view of the model not a "rendered" (using the Rendering dialog) view correct? I would expect this behavior from the live view but not from the rendered view.
  1. Any Suggestions for creating frit pattern on glass
    By mthurnauer in forum Revit Architecture - General
    Last Post: 2013-11-15, 03:11 PM
  2. render cloud and accurate sun/shadow study
    By shenderson in forum Revit Architecture - General
    Last Post: 2012-05-23, 05:48 PM
  3. 2011: Glass color not showing
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2012-02-21, 03:52 PM
  4. Frit pattern curtain wall panel
    By Gatchy in forum Revit Architecture - General
    Last Post: 2008-10-20, 07:19 PM
  5. Trying to create a Milgard EtchMatte Pattern for glass.
    By hdjohnson in forum Revit Architecture - Families
    Last Post: 2004-02-24, 09:51 PM
