Thread: ACCESS EXTENDED DATA???
    2013-08
    46
    Default ACCESS EXTENDED DATA???
    I have attached a screen shot of my properties menu of what I am trying access via autolisp or visual lisp. I am trying to sort the electrical devices in my plan by the style name that is in the extended data (or key). All devices are on *-elec-fx-* layer. when I use (entget(car(entsel))'("*")) to view the xdata the information I am looking for is not there. (see attached extended data2.png). How can I get to this information? I am trying to avoid making a layer for every device and filter it that way.
    I am needing to count the number of each device and then send that number to a variable where I will then use a field in a table to autofill the table.
    Thanks in advance for any help.
    2015-12
    2,095
    Default Re: ACCESS EXTENDED DATA???
    Not everything holds its information in XData. The information may be stored as XRecords in a dictionary on the object; or references to XRecords in a dictionary on the Named Object Dictionary; or through properties embedded in the object that are not accessible through LISP.
    2013-08
    46
    Could I access it via .net? If so does anyone know how?
    2013-08
    46
    I made a post on cadtutor and someone posted the lisp below. This will dump everything associated with it. I was able to get the data I needed listed beside Name (RO) =. Look at the attached png and you will be able to see what all it returned. Now I just have to figure out how to filter for this data. Any ideas? Should I call the dumpit function and then filter for what I need in the return or is there a way I can just get the info I need to return?
    ;;; DumpIt                                                            ;
    ;;; Dump all methods and properties for selected objects              ;
    (defun C:DumpIt ( / ent)
      (while (setq ent (entsel))
        (vlax-Dump-Object
          (vlax-Ename->Vla-Object (car ent))
      (princ)
    2015-12
    2,095
    From my post on one of your other threads, you *really* need to read the API for your product. It will describe the methods and properties applicable to the objects.
  1. Extended Data
    By jkramer in forum ACA General
    Last Post: 2012-10-16, 02:54 PM
  2. Import GIS Parcel data to C3D Parcels with extended data
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-10-06, 04:51 PM
  3. extended data
    By cparvez in forum VBA/COM Interop
    Last Post: 2009-07-17, 09:17 PM
  4. Missing Extended Data Tab
    By JKEDMONDSON in forum ACA General
    Last Post: 2007-10-18, 07:28 PM
  5. Three programs using EXTENDED ENTITY DATA
    By aaronic_abacus in forum AutoLISP
    Last Post: 2007-01-02, 01:13 PM
