Thread: make default "origin-to-origin" instead of "center to center" when linking revit models
    Wish List Administration
    2011-08
    4,581
    Default make default "origin-to-origin" instead of "center to center" when linking revit models
    Summary: make default "origin-to-origin" instead of "center to center" when linking revit models
    Description: When linking revit models (insert]Link Revit) , the default choice for positioning is "Auto - center to center". I wish the default choice would be "Auto - origin-to-origin".
    Product and Feature: Revit MEP - Other
    Submitted By: Bill Bonenberger on 10/24/2013
    I could stop if I wanted to E-Key's Avatar
    2005-04
    Canada
    256
    Default Re: make default "origin-to-origin" instead of "center to center" when linking revit models
    I believe the default option should be "By Shared Coordinates". This the way Revit is designed to keep linked models' location coordinated. Sometimes may happen that a linked model doesn't have established coordinates. For this case Revit uses the "Center-to-Center" insertion method. Actually here the "Origin-to-Origin" should be used.
    2011-08
    4,581
    Exclamation Re: make default "origin-to-origin" instead of "center to center" when linking revit models
    This wish has been reported by a member.
    This thread is closed to further posts while the request is being reviewed by administrators.
    2011-08
    4,581
  1. default for linking revit models = origin to origin
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2017-11-01, 03:28 PM
  2. Change default positioning to origin to origin
    Last Post: 2012-07-20, 01:38 AM
  3. Replies: 2
    Last Post: 2012-07-09, 02:17 PM
  4. origin-to-origin import being forced center-to-center
    By cblackford in forum Revit Architecture - General
    Last Post: 2006-08-14, 11:17 PM
  5. Linked Origin-Origin being overridden to Center-Center
    By tomnewsom in forum Revit Architecture - General
    Last Post: 2006-04-05, 01:57 PM
