Summary: A new command that would allow you to create a legend from selected objects.
Description: I would like to have a command that when run would ask you to select an object; line, block, etc. and then would ask you for a description. Then the program would add that item and description to the legend.
It seems it would be easy enough if you incorporated an acadtable. The legend would be a two column table with a blocks as the first column and text as the second. The blocks would be an identical item as what you had selected previously (other entities would have to be made a block by the program since acadtables do not except anything but blocks) and the description would be whatever you had given it. As a table you could then move rows up or down.
Product and Feature: AutoCAD - Other
Submitted By: Eric Stiles on 10/26/2013
