Thread: Change View Referencing Sheet
    Wish List Administration
    2011-08
    4,581
    Default Change View Referencing Sheet
    Summary: The ability to change the Referencing Sheet Parameter of a view to show the Sheets available.
    Description: The ability to manually select the Referencing Sheet for a view, this would be great as Revit will look for the first probably Sheet in the se and sets the number for you. If there was a pulldown list that would allow you to select the available sheets.
    Product and Feature: Revit Architecture - Annotation Tools
    Submitted By: Scott Crichton on 10/27/2013
    2011-08
    4,581
    Exclamation Re: Change View Referencing Sheet
    Description: The ability to manually select the Referencing Sheet for a view, this would be great as Revit will look for the first sheet in the set and uses that number for you. If there was a pulldown list that would allow you to select the available sheets.
    2008-07
    17
    Default Re: Change View Referencing Sheet
    I think this would be improved if Revit simply showed the view number within sheets in the Project Browser. Currently, when you open the Browser and scroll to the sheet you want, the views on the sheet are not numbered.
    2011-08
    4,581
  1. 2013: how to change default drawing name style on sheet view?
    By rbelfiore337841 in forum Revit MEP - General
    Last Post: 2012-08-08, 10:51 AM
  2. Titleblock Labels Referencing View Placed on Sheet
    By Rosie the Reviter in forum Revit Architecture - General
    Last Post: 2009-10-09, 06:32 PM
  3. View Title - Referencing Sheet
    By Chad Smith in forum Revit - Platform
    Last Post: 2008-02-12, 03:06 AM
  4. Change Size of Perspective View on a Sheet?
    By matthew.113087 in forum Revit Structure - General
    Last Post: 2007-02-19, 11:13 PM
  5. Changing referencing sheet of drafting view
    By Griff in forum Revit Architecture - General
    Last Post: 2004-08-26, 01:52 AM
