Thread: any objects should be joinable
    Wish List Administration
    2011-08
    4,581
    Default any objects should be joinable
    Summary: any two objects should be joinable provided they have the same material
    Description: At the moment there are many types of Revit elements that can be joined, such as roofs and walls, but there are limitations to this -- for example stairs, floors, ramps, toposurfaces which cannot be joined to one another. There is no clear logic behind this limitation and needlessly makes the documentation process more difficult.
    It should be a relatively trivial change to make all 3d objects work the same way.
    Product and Feature: Revit Architecture - Other
    Submitted By: kris treagus on 10/29/2013
    2011-08
    4,581
    Exclamation Re: any objects should be joinable
  1. Ability to snap to all objects in a 3D view, not just objects on the current reference plane
    Last Post: 2010-03-12, 06:09 AM
  2. Pin Position shold lock pinned objects to prevent flexing when adjoining objects change
    Last Post: 2009-03-29, 03:58 PM
  3. Moving Text Objects relative to base point as other Objects are moved / scaled
    By William Troeak in forum Dynamic Blocks - Technical
    Last Post: 2007-02-06, 02:35 PM
  4. Public (Joinable) Custom Usergroups
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2006-12-11, 02:23 PM
