I simply commented out the breaking portion of the routine that is found here by Raymond Rizkallah: http://cadtips.cadalyst.com/2d-opera...ctional-arrows
This seems to work similar though...
;; ** ARROW-BREAK.LSP **
;; * Used to apply BREAKS and ARROWS to objects (as a flow direction).
;; * Valid objects are POLYLINES, LINES and ARCS.
;; * Arrow size is defined by user input
;; * Arrow direction is opposite to the point you use to select object
;; * Written By Raymond Rizkallah - December/1998 ; October/2008
;;----------- valid object selection --------------------------------
(defun RT1 () ;; only LWPOLYLINE or NULL will be selected
(setq ValidEntList '("LWPOLYLINE" "LINE" "ARC"))
(setq ent1 (entsel "\nPick Lwpolyline/Line/Arc: "))
(if (null ent1) (progn (setq txt1 nil) (prin1))
(progn
;(while (/= (cdr (assoc 0 (entget (car ent1)))) "LWPOLYLINE") (RT1))
(while (not (member (cdr (assoc 0 (entget (car ent1)))) ValidEntList)) (RT1))
;(setq txt1 (cdr (assoc 1 (entget (car ent1)))))
(PRINC)
)) ;end if
;; PL-DIRECTION FUNCTION :
;; * Give Polyline length through spcified point PT0.
;; * Specify its direction according to PT0.
(defun PL-DIRECTION ()
(vl-load-com)
(command "ucs" "w")
(RT1)
(setq ename (car ent1) eget (entget ename))
(setq pt0 (osnap (cadr ent1) "nea"))
(setq pt-ur (polar pt0 (* pi 0.25) (* (getvar "viewsize") 0.01)))
(setq pt-ul (polar pt0 (* pi 0.75) (* (getvar "viewsize") 0.01)))
(setq pt-ll (polar pt0 (* pi 1.25) (* (getvar "viewsize") 0.01)))
(setq pt-lr (polar pt0 (* pi 1.75) (* (getvar "viewsize") 0.01)))
(grdraw pt-ll pt-ur 7)
(grdraw pt-lr pt-ul 7)
(setq d1 (vlax-curve-getDistAtPoint (car ent1) pt0)) ;;; the specified point
(setq curarea (vlax-curve-getArea ename))
(setq curperi (vlax-curve-getDistAtParam ename (vlax-curve-getEndParam ename)))
(setq d3 curperi) ;;;TOTAL LENGTH
(setq d2 (- curperi d1))
;(prompt (strcat "L=" (rtos d3 2 2) " : [" (rtos d1 2 2) " + " (rtos d2 2 2) "]. "))
(prompt (strcat " [L= " (rtos d3 2 2) "]"))
(if (< d1 d2)
(progn (setq ctrl1 1)) ;(princ " Same direction."))
(progn (setq ctrl1 -1)) ;(princ " Opposite direction."))
) ; end function
;; C:ARB :: ARROW-BREAK MAIN FUNCTION
(defun C:ARB ()
(COMMAND "UNDO" "M" "UNDO" "G")
(setvar "cmdecho" 0)
(SETVAR "OSMODE" 0)
(setvar "sortents" 117)
(setvar "snapmode" 0)
;;----------- Crating Blocks arw_100 & arw_200 --------------------
(setq as3 0.5)
(if (null (tblsearch "block" "arw_100")) (progn (setvar "fillmode" 0)
(setq p1 (getvar "viewctr") p2 (polar p1 0 (* as3 1)) p3 (polar p1 0 (* as3 2)))
(command "pline" p1 "w" (* 2 (/ as3 3.0)) 0 p3 "" "chprop" (entlast) "" "la" 0 "")
(command "block" "arw_100" p2 (entlast) "")
(setvar "fillmode" 1)
(if (null (tblsearch "block" "arw_200")) (progn (setvar "fillmode" 0)
(command "pline" p1 "w" 0 (* 2 (/ as3 3.0)) p3 "w" 0 0 "" "chprop" (entlast) "" "la" 0 "")
(command "block" "arw_200" p2 (entlast) "")
;;----------- Specifying polyline direction & length --------------
(PL-DIRECTION)
(if (null (numberp arwsz)) (setq arwsz 3.0))
(setq n-arwsz (getdist (strcat "\nArrow size <" (rtos arwsz) ">: ")))
(if n-arwsz (setq arwsz n-arwsz))
;;--------------- Dividing the arrows -----------------------------
(setq len1 (fix (/ d3 (* arwsz 3.5))) len1x (* len1 7)) ; --> --> --> 2+1+0.5=3.5
(if (= ctrl1 1)
(command "divide" ename "b" "arw_100" "y" len1X)
(command "divide" ename "b" "arw_200" "y" len1x)
;;------------ DELETING EXTRA ARROWS ------------------------------
(setq ss1 (ssget "p"))
(setq len1 (sslength ss1) n1 0 ss2 (ssadd))
(if (= ctrl1 1)
(while (< n1 len1)
(setq ename1 (ssname ss1 n1))
(if (or (= n1 5) (= (rem n1 7) 5)) (ssadd ename1 ss2))
(setq n1 (1+ n1))
) ;end while
(while (< n1 len1)
(if (or (= n1 0) (= (rem n1 7) 0)) (ssadd ename1 ss2))
(setq n1 (1+ n1))
) ;end while
) ;end if
(command "erase" ss1 "r" ss2 "")
(setq ss1 ss2)
;;--------- Scaling arrows --------------------------------------
(setq len1 (sslength ss1) n1 0)
(while (< n1 len1)
(setq ename1 (ssname ss1 n1) eget1 (entget ename1))
(setq p1 (cdr (assoc 10 eget1)))
(command "scale" ename1 "" p1 arwsz)
(setq n1 (1+ n1))
) ;end while
;;--------- Make Polyline First Entity - ENAME ------------------
(command "copy" ename "" "0,0" "@" "erase" "p" "")
(setq ename (entlast)) (redraw ename)
;;--------- Braking Polyline -------------------------------------
(setq len1 (sslength ss1))
(if (= ctrl1 1) (setq n1 0) (setq n1 1))
(if (= ctrl1 1)
(while (< n1 (1- len1))
(setq p1 (cdr (assoc 10 eget1))) ;;; insertion point of arrow
(setq dist@-X (vlax-curve-getDistAtPoint ename p1))
(setq PT1 (vlax-curve-getPointAtDist ENAME dist@-X)) ;;; POINT @ insertion point
(setq PT2 (vlax-curve-getPointAtDist ENAME (+ dist@-X arwsz))) ;;; NEXT POINT
(COMMAND "BREAK" ename PT1 PT2)
(setq n1 (1+ n1))
) ; end while
(while (< n1 len1)
(setq PT2 (vlax-curve-getPointAtDist ENAME (- dist@-X arwsz))) ;;; NEXT POINT
(setq n1 (1+ n1))
) ; end while
) ;end if
(setvar "cmdecho" 1)
(COMMAND "UNDO" "E") (princ)
) ; end main function
(prompt "\n Start command with [ARB]. ") (princ)
