Results 1 to 7 of 7
Thread: Plan Symbol Masking
    AUGI Addict sfaust's Avatar
    2004-01
    Littleton, CO (Denver Metro)
    1,535
    Lightbulb Plan Symbol Masking
    There are a lot of fixtures and things out there that are great models in 3d, but would look rediculous in plan because of all the faceting. So you use symbolic lines to draw the symbol in plan, cool. The only problem is that if you put it over something (i.e. a faucet above a sink or a toilet above a tile floor) it is transparent. You can't draw a symbolic filled region in a family so you're stuck. You can do an extrusion in the shape of the outline, but then it shows up in 3d.
    Solution: You can't draw a filled region in the family, but you can nest a detail component into it. So copy the linework, create a new detail component family, paste the linework in place, then make a solid white filled region. Then nest the detail component into the family and properly align, etc. The family will look correct in 3D and will mask objects beneath it correctly
    100 Club m_cahoon14336's Avatar
    2004-02
    Jonesboro, AR
    186
    Default Re: Plan Symbol Masking
    sfoust, could you post an example of this? Thanks, Colquhoun
    Colquhoun
    Wrong is wrong even if everyone is doing it; right is right even if no one is doing it. - St. Augustine
    2003-05
    5,153
    There are some families posted in this thread, that may help.
    Quote Originally Posted by Colquhoun
    2003-04
    London NW9
    377
    Why cant we just have the ability to use filled regions directly within the family editor ? ? ?
    It can be a management overhead to have a detail component linked into the family.
    2002-02
    St. Louis, MO
    4,695
    Speed and flexibility. These hybrid familes I make are fast. They don't slow the project down at all. You can also nest details for fine/med/coarse detail with little effort. If your had to do this with filled regions within the main family it would be a blur of ref planes and parameters. This technique is clean and simple.
    2004-01
    1,535
    doo... guess I should have searched before posting. I didn't know that you could do that.
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    I just turn the visibility on of on main solid, For example a table or counter top just the top will be visible in plan. With a toilet I just make a "toilet seat" that is visible and a tank top.
    But I do believe the nested detail component will be faster in regen times.
    Scott D. Brown, AIA
    BECK
  1. 2015: Plan Production - Matchline Masking
    By blippold in forum AutoCAD Civil 3D - General
    Last Post: 2015-06-08, 05:18 PM
  2. Masking Symbol within Family
    By Wish List System in forum Revit MEP - Wish List
    Last Post: 2013-10-24, 06:19 PM
  3. 2013: masking region in symbol family
    By mcheckis366322 in forum Revit Architecture - General
    Last Post: 2013-03-29, 07:40 PM
  4. MVPart with 2d plan symbol
    By mwalker.87963 in forum Parts Builder
    Last Post: 2011-05-24, 01:40 AM
  5. Masking/Filled Regions won't work in Roof Plan
    By ryanpkremer in forum Revit Architecture - General
    Last Post: 2009-06-18, 06:05 PM
