Thread: Identify blocks with same name and replace them with another block
    2006-03
    19
    Default Identify blocks with same name and replace them with another block
    Is there a way to identify blocks that have the same name and placed at a common scale and then replace them with another block at the same scale?
    If so, how would that be best accomplished?
    Thanks
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,082
    Default Re: Identify blocks with same name and replace them with another block
    You could use QSELECT to identify specific blocks with certain properties.
    I believe BLOCKREPLACE will allow you to replace selected blocks.
    2006-03
    19
    Yep, BLOCKREPLACE worked like a charm.
    Thanks!
  1. Replies: 0
    Last Post: 2012-09-20, 04:53 PM
  2. Replace blocks
    By nextvkin in forum AutoCAD General
    Last Post: 2009-01-29, 01:45 AM
  3. Identify nested block host w/ VBA
    By mcoffman in forum VBA/COM Interop
    Last Post: 2006-11-30, 04:11 PM
  4. Identify the locations of blocks in a dwg
    By BCrouse in forum AutoCAD General
    Last Post: 2006-02-20, 06:59 PM
  5. Replace blocks
    Last Post: 2006-01-10, 12:39 AM
