Results 1 to 6 of 6
Thread: Make scroll down bar wider on Layers Panel in the Home Tab Ribbon
    Wish List Administration
    2011-08
    4,581
    Default Make scroll down bar wider on Layers Panel in the Home Tab Ribbon
    Summary: Software interface now too fiddly with this feature to use and wastes time
    Description: This feature used to be the same width as that in the Layer Properties Manager Dialog Box but is now too narrow and time consuming to select.
    Also when you scroll up and the number of layers in your drawing it is easy to slip off this feature and this then reverts back to its parked position inside te Layers Panel
    Subsequently when I am trying to change a part from one layer to another this operation can often fail due to this narrow scroll bar selection area being difficult to operate.
    It is very frustrating, this is not an improvement of the software interface
    Product and Feature: AutoCAD - Layer
    Submitted By: Richard Burnett on 11/13/2013
    0,0,0 The Origin
    8,570
    Default Re: Make scroll down bar wider on Layers Panel in the Home Tab Ribbon
    Quote Originally Posted by Wish List System View Post
    Yes, please. While you're at it, apply the same to the Properties Manager slider.
    John B
    2015-10
    Colorado Springs, CO
    369
    I like that dropdowns in ribbons such as layers, linetypes, etc have smaller scroll bars in the ribbon... of course I don't use the ribbon much. Wider scroll bars means less information visible in the pulldown or simply wider ribbon panels taking up more screen real estate. Maybe this is something that a variable could be applied to through the display settings.
    "I think I fish, in part, because it's an anti-social, bohemian business that, when gone about properly, puts you forever outside the mainstream culture without actually landing you in an institution." - John Gierach
    2017-03
    I second this! When I used AutoCAD 2006 I remember being able to expand the layers menu to the desired width. What we are really needing is to be able to modify the width, not for it to be wider, but to be able to adjust it to the desired size, big or small.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,376
    The Layer List Combo Box RIBBONCONTROL for 2017 expands when selected wide enough to display the widest layer name, no need to adjust manually.
    I keep the Layer & Property Palettes docked to the right, wide enough to see whatever I need, and set to auto-hide.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    Earth
    9,780
    While you wait around for that, QuikPik has been doing it for years, with the layer toolbar.
    R.K. McSwain | CAD Panacea |
  1. Wider scroll bars in drop down menus
    Last Post: 2013-11-15, 03:12 AM
  2. Use Mouse Scroll Wheel to Change Ribbon Tabs
    Last Post: 2012-12-06, 04:51 AM
  3. Home Tab in Ribbon is Missing
    By cdsuggs in forum Revit MEP - General
    Last Post: 2010-06-30, 06:23 PM
  4. Scroll Bar in Properties Manager to be Wider
    Last Post: 2008-10-12, 05:10 PM
  5. How do I convert a 2008 Dashboard Panel to a Ribbon Panel?
    By jpaulsen in forum AutoCAD CUI Menus
    Last Post: 2008-08-28, 01:00 PM
