Thread: Multiple Monitor Views
    Wish List Administration
    2011-08
    4,581
    Default Multiple Monitor Views
    Summary: I want to be able to drag multiple views onto a 2nd or 3rd monitor WITHOUT having to stretch the main display onto two neighboring monitors.
    Description: Currently only the Properties, System Browser and Project Browser windows can be dragged out of the main Revit display and placed wherever you want onto second and third monitors. This works the same as any other Windows based application can be moved around on multiple monitors.
    Views should also be able to be dragged off in the same way. Any given view (when it is reduced from full size to partial size) should be able to get dragged anywhere like the above mentioned items can be.
    Product and Feature: Revit MEP - Views - Area Plan
    Submitted By: Bill Mutert on 11/19/2013
    Default Re: Multiple Monitor Views
    Contact some of the old Bentley programmers. Microstation has always been able to easily utilize dual monitors. If you open 1, or 2, or 4 or 8, they will always line up with the edge of the monitor so you don't get views crossing monitors. If you get the project browser and properties width just right, it will split correctly, but change the width or turn off the project browser and when you Tile your views, they do not take into account where the edge of your monitor stops.
    There is a way to do it, I cant believe it is not already part of Revit!
    I could stop if I wanted to zanzibarbob7's Avatar
    2004-08
    Wayne, ME
    444
    This is something I have had on the wish list for many years. Photoshop does it and I am sure many Revit users work with multiple monitors. I want to work in Plan and watch my 3D and Section on another monitor. I think this could be fixed on the next update. Please do it!
    2018-09
    Hello All,
    This was recently implemented in Revit 2019!
  1. Multiple monitor support
    By IanR in forum Revit Architecture - Wish List
    Last Post: 2013-11-15, 01:59 PM
  2. Multiple Monitor Support
    Last Post: 2012-11-30, 01:44 PM
  3. 2012: Undock views or sheets to second monitor
    By turnbullp in forum Revit Architecture - General
    Last Post: 2012-04-25, 04:44 PM
  4. Multiple Monitor Support
    Last Post: 2009-02-10, 10:57 PM
  5. Multiple Monitor Support
    By eric.198284 in forum Revit Structure - Wish List
    Last Post: 2008-12-04, 04:26 AM
