Thread: How to change dynamic block attribute default values based on block selected?
    2011-07
    Default How to change dynamic block attribute default values based on block selected?
    I was wondering if anybody knew how to change the default value of a dynamic block attribute depending on which dynamic block is selected?
    Example: Block 1 selected, Attribute Tag: Block_Number, Attribute default: 1
    Select Block 2 and attribute default value changes to 2.
    2015-09
    154
    Default Re: How to change dynamic block attribute default values based on block selected?
    Are you using block visibility parameters to select between block 1 and block 2 etc? if so name the visibility as the attrtibute should appear. Then in the attribute use a text field and link it to the block visibility parameter.
    if that is not what you need maybe you could post a sample drawing.
    2009-01
    B5
    544
    Always posting a sample DynBlk is the way to go.
  1. Replies: 13
    Last Post: 2012-09-18, 07:51 PM
  2. Block Attribute Table Values Dont' Appear in Block
    By stusic in forum Dynamic Blocks - Technical
    Last Post: 2011-12-27, 02:58 PM
  3. Using Attribute values to control Dynamic Block actions
    By bshank.140587 in forum Dynamic Blocks - Technical
    Last Post: 2007-06-17, 02:12 AM
  4. Block attribute text size is incorrect when the Block is not selected
    By lwhitney.133796 in forum AutoCAD General
    Last Post: 2007-02-16, 10:01 PM
  5. Extract Dynamic Block Attributes, values change as Block changes
    By dave.buckberry in forum Dynamic Blocks - Technical
    Last Post: 2006-09-05, 04:38 PM
