Thread: Pressure Pipe Network in 2013
    2015-10
    Plattsburgh, NY, USA
    5
    Default Pressure Pipe Network in 2013
    Has anyone found decent success with using the Pressure Pipe Network in Civil3D 2013? I just recently began developing an Apputenace library for all the parts we use that were not included with the program. I have run into a few big issues that could prevent our firm from using this potentially useful tool. One issue, does the PPN posses the ability to create structures like manholes? This could be a really break point for using it to do a sewer line. Another, how well does it interact with multiple surfaces? If I have two surfaces butted up to one another how to a get a PPN from point A on surface 1 to point B on surface 2 and have that PPN respond at the correct bury depth while creating the correct fittings? As I experiment more this this tool I feel as if there are way more questions about what it can and can't do compared to what a regular pipe network does. Anyone have thoughts?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Pressure Pipe Network in 2013
    I found it was too limiting in its' initial release with 2013, therefore I stopped using it. I was going to look into it again once the office moves to 2014.
    For the surface question, create a third surface and paste the other two surfaces into it. Use the third surface for your design.
  1. Pressure Pipe Network Libraries for Civil 3D...?
    By pauldeyo438916 in forum AutoCAD Civil 3D - General
    Last Post: 2015-08-20, 04:33 PM
  2. pressure network labels
    Last Post: 2014-10-25, 05:09 PM
  3. Data Reference a Portion of a Pipe Network or Pressure Network
    Last Post: 2013-12-19, 04:09 PM
  4. Pressure Pipe Network in Cross sections
    Last Post: 2013-11-15, 01:31 PM
  5. Data Shortcut Pipe Network & Design Pipe Network
    By Openwheeler in forum AutoCAD Civil 3D - Pipes
    Last Post: 2012-09-18, 03:47 PM
