Summary: Include a button to the Warning Box to add a leader when a Room Tag is pulled outside the room boundaries.
Description: Currently when a Room Tag is pulled away from the room a warning box appears stating the "Room Tag is outside of its Room. Enable Leader or move Room Tag within its Room."
The buttons "Move to Room" and "Cancel" work as described.
The OK button doesn't work properly, IMO. It should be renamed to "Add Leader."
The Current procedure is to move the Room Tag --> click OK. Now the Room Tag is blank (worthless). Then on the Options bar select "Leader" and the Room Tag is no re-associated to the room.
If the "Add Leader" button replaced the "OK" then all of the options would be available within the Warning box.
Yes, this is a very minor inconvenience when compared to other major items.
Product and Feature: Revit Architecture - Annotation Tools
Submitted By: Rick Buch on 11/25/2013
