I was curious to know if anyone knows of a LISP routine that can create multiple paper space layout tabs and can name them incrementally. Your help is greatly appreciated.
Welcome to AUGI!
This should get you started (case-sensitive):
Code:(vl-load-com) (defun c:LAYOUT+ (/ *error* prefix i n acDoc oLayouts layoutName) (defun *error* (msg) (if acDoc (vla-endundomark acDoc) ) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** "))) ; Fatal error, display it ) (princ) ) (if (and (setq prefix (getstring "\nEnter layout name prefix: ")) (setq i (getint "\nEnter starting index number: ")) (setq n (getint "\nEnter ending index number: ")) (< i n) (princ "\nWorking, please wait... ") (princ) ) (progn (vla-startundomark (setq acDoc (vla-get-activedocument (vlax-get-acad-object))) ) (setq oLayouts (vla-get-layouts acDoc)) (setq i (1- i)) (while (< i n) (setq layoutName (strcat prefix (itoa (setq i (1+ i))))) (if (not (vl-position layoutName (layoutlist))) (progn (princ (strcat "\nCreating layout \"" layoutName "\"... ")) (princ) (vla-add oLayouts layoutName) (princ "Done. ") ) (progn (princ (strcat "\nLayout \"" layoutName "\" already exists. ") ) (princ) ) ) ) ) (cond (n (prompt "\n** Invalid indexes entered ** ")) (i (prompt "\n** Must enter an ending index ** ")) (prefix (prompt "\n** Must enter a starting index ** ")) ) ) (*error* nil) )
Computer Specs:
Also, I've moved this thread to the LISP forum.
Computer Specs:
The Lisp worked perfect. However I should have been more specific as far as content. I have a template set up and I wanted to copy the content on let's just say tab2 10 more times and name them incrementally. This would have worked perfect if it could have copied the content included in the layout from tab2 to be specific.
@BB
If the user pressed ENTER with the function GETSTRING it would return an empty string "" which means a value to AND function
... And then?
Computer Specs:
Computer Specs:
