Thread: Editing parcels
    2009-11
    Raleigh, NC
    974
    Default Editing parcels
    I have 2 parcels that share a radius. I want to remove the radius completely so that the shared lot lines meet at PI.
    I am hoping to make this change without losing lot #s.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Editing parcels
    I am not certain I completely understand what you are wanting to do.
    Did you know you can renumber the parcels? You can find this option in the Ribbon and the menu bar for Parcels.
    2009-11
    Raleigh, NC
    974
    Sorry Opie, I try to make the point efficiently in consideration and sometimes I find that efficiency lacks a clear point.
    I want to delete the curve (ignore Cyan line in image) that lot 22 & 29 share and extend both tangents to a PI. I went to "Parcel Layout Tools" and used the "Delete Sub-Entity" command for the curve. That's where I was unsure of what to do next to reconstruct lot 22 & 29. I used the "Add fixed lines - two points" and renumbered the lots. That achieved my objective but it feels like I could have used the "Edit Parcel Commands" to modify rather than redraw.
    What would you have done?
    2002-01
    jUSt Here (a lot)
    9,196
    Quote Originally Posted by tim_newsome View Post
    I don't know. I seldom use Parcels in my daily drafting as they are not part of my focus at my firm.
    What you have done worked. But I agree, you should be able to use the Edit Parcel Commands to do what you needed to do without removing and replacing the curve.
  1. 2014: Parcels
    By mgonzales361438 in forum AutoCAD Civil 3D - Parcels
    Last Post: 2013-12-11, 07:41 PM
  2. Grip Editing Parcels
    By WScottAllenPE in forum AutoCAD Civil 3D - Parcels
    Last Post: 2011-09-23, 07:44 PM
  3. 2008 Parcels
    By andy in forum AutoCAD Civil 3D - Parcels
    Last Post: 2007-07-27, 01:07 PM
  4. Parcels disappearing...
    By whf in forum AutoCAD Civil 3D - Parcels
    Last Post: 2007-05-22, 05:25 PM
  5. Renumbering Parcels
    By eduley in forum AutoCAD Civil 3D - General
    Last Post: 2005-02-07, 05:47 AM
