Results 1 to 6 of 6
Thread: Revit Structure 2013 Area reinforcement cut by shaft
    2015-09
    8
    Default Revit Structure 2013 Area reinforcement cut by shaft
    Hi,
    I have now one question, I don´t know if it is possible to make Revit work in another way:
    I have one concrete slab, and I have modeled some area reinforcement in it. Now I place a shaft that cuts the slab, but I don´t want the shaft making the rebar being automatically cut as well (odd behaviour, I know, but this is what the engineers want...).
    Is there any way to acomplish this?
    Thank you.
    2002-09
    Madison, WI
    5,687
    Default Re: Revit Structure 2013 Area reinforcement cut by shaft
    so you want a hole in a slab and you want the rebar to be continuous across the opening?
    2015-09
    8
    strange, but that´s exactly what I want.
    2002-09
    Madison, WI
    5,687
    I think in order to do that you'll need to use the modeled rebar and not the area reinf. The area reinf (I believe) acts more like a detail component. I don't think you'll be able to get the results you want using that. Depending on how messy your slab is, modeling rebar is rather simple and I find gets you better results. It can also be a little more work.
    2015-09
    8
    Thanks for the answer.
    Yes, I think I will have to do it just by modelling rebar, and not area reinf.
    I just wanted to check if it was somehow possible in order to keep the area reinforcement symbol funcionality.
    2002-09
    Madison, WI
    5,687
    You could place the modeled rebar, then pull back the extents so it's just at the opening and leave the area reinf as it is.
    Just a thought.
  1. SE204-2: Concrete Reinforcement with Autodesk Revit Structure and Robot Structural Analysis
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:46 AM
  2. Regarding Revit Structure Suite 2013
    By durentech in forum Revit Structure - General
    Last Post: 2012-05-01, 02:11 PM
  3. Extensions for Revit Structure 2013
    By david_peterson in forum Revit Structure - General
    Last Post: 2012-04-26, 03:32 AM
  4. Rebar/Reinforcement Scheduling Area Reinforcement
    By hannes in forum Revit Structure - General
    Last Post: 2009-09-29, 04:00 AM
