Thread: Cannot select any objects in drawing
    2013-12
    Default Cannot select any objects in drawing
    I have received an Autocad drawing to modify some objects in. However, I am unable to select any of the objects in the figure, i.e. when I move over an object it is not highlighted. I have added a snapshot in the attachment!
    Can someone help me out here? Thanks!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,750
    Default Re: Cannot select any objects in drawing
    I don't use the Mac version. With that, the only thing I can think of would be the PICKFIRST system variable. That is probably not it, but it is the first thing I would typically try.
    Earth
    9,802
    The UCS icon indicates you are in paper space. Maybe the objects are in model space?
    R.K. McSwain | CAD Panacea |
    2016-09
    Manchester
    3
    Maybe try running an audit and a purge on the dwg. If that doesn't work I'd give'r a restart to see if the problem remains.
  1. 2011: Can't select objects in drawing
    By thinkdesign_liesl in forum AutoCAD General
    Last Post: 2011-01-28, 12:33 AM
  2. Can only select objects once.
    By cadmecheng in forum AutoCAD General
    Last Post: 2006-11-02, 12:11 PM
  3. Can not select objects
    By cconfer in forum AutoCAD General
    Last Post: 2006-10-23, 04:35 PM
  4. Unable to select OLE (eg Excel) Objects within drawing file
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-26, 07:05 PM
  5. Replies: 3
    Last Post: 2004-06-14, 06:50 PM
Tags for this Thread
