Thread: Text Modification Routine Needed
    2000-10
    Orlando, Florida
    38
    Default Text Modification Routine Needed
    A major client wants searchable PDFs for our deliverables. Unfortunately, we're still using SHX fonts, some of which do not have a width of 1.
    I desperately need something I can add to my Accaddoc.lsp that will automatically, upon opening a drawing:
    1) Select all Model Space text (not in attributes) and set the width to a value of 1
    2) Create the text style Arial, created with font Arial.ttf, width 1
    3) Change all the selected Model Space text to style Arial
    4) Immediately do a save
    If anyone can whip up something like this it would be greatly appreciated (and it will be added to the accaddoc with your at the head of the routine).
    Thanks
    2010-10
    535
    Default Re: Text Modification Routine Needed
    Quote Originally Posted by Mitch Mermel View Post
    Thanks
    (defun c:AllArial  (/ AllText i e l)
    ;;;	pBe 17Dec2013		;;;
          (if (not (tblsearch "STYLE" "ARIAL"))
                (entmake
                      '((0 . "STYLE")
                        (100 . "AcDbSymbolTableRecord")
                        (100 . "AcDbTextStyleTableRecord")
                        (2 . "ARIAL")
                        (70 . 0)
                        (40 . 0.0)
                        (41 . 1.0)
                        (50 . 0.0)
                        (71 . 0)
                        (42 . 0.2)
                        (3 . "ARIAL.TTF")
                        (4 . "")
          (if (setq AllText
                         (ssget "_X"
                                '((0 . "*TEXT") (410 . "Model"))))
                (repeat (setq i (sslength AllText))
                      (setq e (entget (ssname AllText (setq i (1- i))))
                            l (assoc -1 e))
                      (setq e (entmod (list (cons 7 "ARIAL") l)))
                      (entmod (list (cons 41 1.0) l))
          (princ)
    EDIT: forgot about the width
  1. Replies: 3
    Last Post: 2015-01-05, 03:05 AM
  2. Modification to a LISP routine
    By cwjean76 in forum AutoLISP
    Last Post: 2008-05-19, 06:32 PM
  3. Routine needed
    By tsigler in forum AutoLISP
    Last Post: 2008-03-21, 02:22 PM
