Summary: People have enough of hidden mysterious buttons and multiple menu screens.
Description: I'm a Revit trainer. Everyday i show people how revit works. They complain that they are architects not IT. For example when you try to override host layers in a view, you type VG, then check "Cut Line Styles" button to activate Edit button!!! Then click Edit button and then new window with setup buttons is finally opening. So many clicks before doing anything. This is so abstract!
When you need to change the material in a wall, you must click on the name of a material, then little button without any name or description appears at the end of the line. And finally you click this button and new window appears - there you can change the material.
Product and Feature: Revit Architecture - Other
Submitted By: Szymon Czykwin on 12/20/2013
