Results 1 to 6 of 6
Thread: cannot create central file in revit server
    2012-05
    29
    Default cannot create central file in revit server
    Guys,
    please see attach png file, it shows that my server have the x and I cannot add anything on it like creating central file.
    and also the default localhost in webpage how can I change it?
    any process that I miss?
    thanks a lot.
    100 Club meng005's Avatar
    2006-05
    Seattle, WA
    180
    Default Re: cannot create central file in revit server
    Are you able to connect to Revit Server from Revit, but you cannot connect via Revit Server Administrator? If that is the case, consider the solution here: http://blogs.rand.com/support/2012/0...nistrator.html
    The last part is re-registering the IIS component. That fixes the typical reason for the error message.
    2012-05
    29
    thanks for the reply, i change the ip adress in RSN.ini and it works well.
    but i have the problem in connecting local revit.
    here is what i did in my set up,
    i use VMware to install RS 2013 and satisfy all the requirements, i also try to use the windows 7 machine which i put my vmware and it also works perfectly connecting to revit server accelerator, but when i use separate machine and configuring rsn.ini, and when i try to connect my revit local it says revit server accelerator cannot be found.
    any process that i miss?
    thanks
    2006-05
    Seattle, WA
    180
    Quote Originally Posted by markclarenzze View Post
    ...i use VMware to install RS 2013 and satisfy all the requirements, i also try to use the windows 7 machine which i put my vmware and it also works perfectly connecting to revit server accelerator, but when i use separate machine and configuring rsn.ini, and when i try to connect my revit local it says revit server accelerator cannot be found.
    Are you able to ping to the DNS or IP of the Revit Server Accelerator? Furthermore, verify that you can telnet to the accelerator: DOS command prompt -> telnet %acceleratorname% 808
    2012-05
    29
    Ping is successful, but the telnet it says could not open connection to the host, on port 808: connection failed
    2006-05
    Seattle, WA
    180
    That is why you cannot connect. Sounds like a firewall issue on port 808. It could be from the Windows Desktop, the Revit Server Accelerator, or any other device in between. In rare situations, it could be the ISP.
  1. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  2. 2013: New central file on Revit server
    By MikeJarosz in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2012-10-03, 02:27 AM
  3. 2012: Revit Server - File crashes when creating new central
    By jperry.68875 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-11-17, 02:45 PM
  4. Can you create a local server on same machine as a Central Server?
    By ninnes in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-06-11, 07:47 PM
  5. Linked files in a central file living in Revit Server
    By Steve_Bennett in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-03-29, 01:06 PM
