Thread: Batch routine to open dwg files that are zipped!!
    2013-12
    8
    Question Batch routine to open dwg files that are zipped!!
    Alright I have a simple batch/scr/lisp routine that opens cad files runs a purge routine on them, saves and quits. My issue is that my company loves to unnecessarily zip every single dwg file. Is there a possible way to have my routine open the zipped dwg files and run the same process I already have in place?
    Thanks for any help!!
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,145
    Default Re: Batch routine to open dwg files that are zipped!!
    Quote Originally Posted by Jgoduti25 View Post
    Really? I don't think I even want to know the rationale for that workflow.
    How do you currently open the drawings? How do you zip them after you modify them?
    You could possibly invoke this through the shell.application object. There is some vbscript code out there that shows how to extract files from a zip file.
    2013-12
    8
    I use a batch routine to open autocad and then a .dwg file. I need it to open the zip file then the dwg then run my lisp.
    we use winzip.
    Hmm I also do not need to extract the file. Im starting to think this not only doesnt make sense to a normal person haha but cant be done.
    here is the processs basically im looking for.
    Open Autocad
    Open "filename" using winzip
    Open "*.dwg"
    run lisp
    save
    quit
    I have most of this working successfully. I just need the zip part.
    2013-07
    66
    I believe you can do this via a .bat file.
    Here's an example (save this in notepad as a .bat) and double click, after having changed the paths within to the correct paths on your machine.
    FOR %%f in ("C:/YourFolder/Folder/SubDir/*.dwg") do start /wait C:\"Program Files"\Autodesk\"AutoCAD Mechanical 2012"\acad.exe "%%f" /b "C:/YourDir/SubDir/AUTOCADSCRIPT.scr"
    In conjunction with information from the following link:
    http://kb.winzip.com/kb/entry/125/
    Have fun!
  1. Replies: 14
    Last Post: 2019-01-02, 07:41 PM
  2. 2015: Zipped tutorial files nightmare - SOS!!!
    By southpaw49 in forum Inventor - General
    Last Post: 2014-06-02, 08:05 PM
  3. Replies: 10
    Last Post: 2010-10-13, 03:54 PM
  4. Batch routine to clean up Blocks within DWG files
    By george.arq in forum AutoLISP
    Last Post: 2007-01-25, 12:33 PM
  5. Routine to Batch Edit Blocks
    By CADdancer in forum VBA/COM Interop
    Last Post: 2006-09-19, 09:35 PM
Tags for this Thread
