Results 1 to 6 of 6
Thread: Math in .Net
    100 Club matt.worland's Avatar
    2015-12
    Denver, CO USA
    174
    Default Math in .Net
    Im trying to port over some code and Im still fairly new to .net and cant readily find functions when needed.
    How would I translate this code to vb.net
    (or
       (and (= (car P2) (car P1)) (< (cadr P1) (cadr P2))) ;UP
       (and (< (car P1) (car P2)) (< (cadr P1) (cadr P2))) ;UP-Right
       (and (< (car P1) (car P2)) (= (cadr P2) (cadr P1))) ;Right
       (and (< (car P1) (car P2)) (> (cadr P1) (cadr P2))) ;Right-Down
    (setq P1 (polar P1 (angle P1 P2) 0.0625))
    matt
    matt worland
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Default Re: Math in .Net
    Its untested but it is something like this.
    Imports Autodesk.AutoCAD.Geometry
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports Autodesk.AutoCAD.Runtime
    Public Class Class1
        Private Function Polar5Net(ByVal objPoint1 As Point2d, ByVal objPoint2 As Point2d)
            On Error Goto OnError
            If (objPoint1.X = objPoint2.X And objPoint1.Y < objPoint2.Y) Or _
               (objPoint1.X < objPoint2.X And objPoint1.Y < objPoint2.Y) Or _
               (objPoint1.X < objPoint2.X And objPoint1.Y = objPoint2.Y) Or _
               (objPoint1.X < objPoint2.X And objPoint1.Y > objPoint2.Y) Then
                With objPoint1.GetVectorTo(objPoint2)
                    Return objPoint1.Add(.DivideBy(.Length / 0.625))
                End With
            End If
    OnError:   Return Nothing
        End Function
        <LispFunction("Polar5")> _
        Public Function Polar5LISP(ByVal rbfLISPArguments As ResultBuffer)
            On Error GoTo OnError
            Dim arrLISPArguments As TypedValue() = rbfLISPArguments.AsArray
            If arrLISPArguments.Length = 2 Then
                Dim objPoint1 As Point2d = CType(arrLISPArguments(0).Value, Point2d)
                Dim objPoint2 As Point2d = CType(arrLISPArguments(1).Value, Point2d)
                Return Polar5Net(objPoint1, objPoint2)
            End If
    OnError: Return New TypedValue(LispDataType.Nil, -1)
        End Function
    End Class
    I made a few modifications and exposed the function to LISP too.
    AutomateCAD
    2009-11
    5,719
    using Autodesk.AutoCAD.Geometry;
    using System;
    namespace BlackBox.AutoCAD.Geometry
        public class Sample
            object Foo(Point2d pt1, Point2d pt2, double length) //PolarIf
                object ret = null;
                if (pt1.X == pt2.X && pt1.Y < pt2.Y | // up
                    pt1.X < pt2.X && pt1.Y < pt2.Y | // up-right
                    pt1.X < pt2.X && pt1.Y == pt2.Y | // right
                    pt1.X < pt2.X && pt1.Y > pt2.Y // right-down
                    double ang = pt1.GetVectorTo(pt2).Angle;
                    ret = new Point2d(pt1.X + length * Math.Cos(ang),
                        pt1.Y + length * Math.Sin(ang));
                return ret;
    * Note - I typically reserve Try, Catch, Finally blocks for main code, unless the Method being called is unable to preclude an exception through code logic.
    Computer Specs:
    2015-12
    Denver, CO USA
    174
    Thank you guys, I was in the middle of writing a GetVectorTo function. I was hoping Autodesk didnt leave out the little stuff.
    I appreciate the examples,
    matt
    matt worland
    2009-11
    5,719
    Quote Originally Posted by matt.worland View Post
    You're welcome; I'm happy to help.
    Along the lines of 'examples', one could also implement a simple Extension Method, which would reduce my code above, to this:
        public class Sample
            static object Foo(Point2d pt1, Point2d pt2, double length)
                return pt1.PolarIf(pt2, length);
    ... And here's the dependent Extension Method:
    using System;
    namespace Autodesk.AutoCAD.Geometry
        public static class Point2dExtensions
            public static object PolarIf(this Point2d pt1, Point2d pt2, double length)
                object ret = null;
                return ret;
    Cheers
    Computer Specs:
    2009-11
    5,719
    ... I was in the middle of writing a GetVectorTo function. I was hoping Autodesk didnt leave out the little stuff.
    Also worthy of note; Object Browser is your friend.
    Computer Specs:
  1. Revit Math
    By ThinkRevit in forum Revit Architecture - Families
    Last Post: 2012-10-18, 05:33 PM
  2. Replies: 1
    Last Post: 2011-12-14, 11:51 PM
  3. Looking for a math genius
    By robert.manna in forum Revit Architecture - Families
    Last Post: 2009-09-24, 11:50 PM
  4. Autocad Math?
    By Anthony Rhodes in forum AutoLISP
    Last Post: 2008-12-01, 06:15 PM
