Results 1 to 6 of 6
Thread: Running VBA Sub on Startup
    2009-12
    7
    Default Running VBA Sub on Startup
    I am having trouble getting a VBA Script to run on startup. My acad.dvb loads automatically but my AcadStartup subroutine does not execute. It works fine when started manually so I know my code is good. Note this is ACADE 2014 on a Windows 8.1 machine. Thanks.
    This is the code:
    Public Sub AcadStartup()
    CopyReportFiles 'My code for copying reports format files.
    ThisDrawing.Utility.Prompt "Acad Startup Scripts Completed." & vbCrLf
    End Sub
    This is the command line output:
    Initializing VBA System...
    Loading VBA startup file...Loading Electrical modules...
    Loader application completed.
    Turlock, CA
    6,420
    Default Re: Running VBA Sub on Startup
    Look at this thread and see if it helps.
    C:> ED WORKING....
    LinkedIn
    2009-12
    7
    Ed,
    I had seen that post and none of it helped. ACAD.dvb loads fine, ACADStartup doesn’t execute.
    Not being unable to figure out why this won’t work I came up with a work around. I inserted a vbarun command within the Acad.lsp file to call my startup subroutine.
    In doing that I did discover that the vbarun command will not execute a macro with the name ACADStartup. It will return an execution error. Not sure why this is so but it seems to be the case on my machine.
    Tim
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    560
    Maybe it is not running because VBA module is not yet loaded. It is loaded automatically when you issue a command that needs it, as in the case of VBARUN in acad.lsp. Try including the "acvba.arx" in your Startup Suite.
    or;
    You can force vba to initialize by putting a line with "acvba.arx" in a txt file called "acad.rx". Create this with Notepad and save where acad.exe is.
    2009-12
    7
    After digging around I figured out what was happening.
    When I created ACAD.dvb I must have copied a project that had a ThisDrawing.ACADStartup already in it. So the system didn’t know whether to run ThisDrawing.ACADStartup or MyModule.ACADStartup, which I created.
    Also, executing –vbarun from the command line didn’t know what to do either, hence the execution error.
    Thanks for your time.
    Turlock, CA
    6,420
    At least you got it working.
    C:> ED WORKING....
    LinkedIn
  1. How can I make a startUp Exe for Startup AutoCAD
    By 740176597380946 in forum ARX
    Last Post: 2013-05-24, 05:36 AM
  2. Run sub at startup
    By jason907238 in forum Dot Net API
    Last Post: 2010-11-18, 06:16 PM
  3. TL on startup...
    By SupremeTaco in forum Revit Architecture - General
    Last Post: 2009-01-15, 04:08 PM
  4. VBA and Startup Suite
    By mboyer in forum VBA/COM Interop
    Last Post: 2007-01-16, 09:26 PM
  5. Startup Dialogue Box
    By martyk in forum AutoCAD General
    Last Post: 2005-02-02, 04:43 PM
