Thread: Using fields for note #s
    2014-01
    Default Using fields for note #s
    I'm trying to insert a field for note #- as in "see note #xx, sheet xx". No problem with the sheet no. field, but I can't figure out how to enter a field for the note # in the plan set sheets to coorespond to the note number on the sheet with the notes on it. Can someone help?
    Earth
    9,805
    Default Re: Using fields for note #s
    It's not super easy to explain, but once you "get it", it's not that hard of a process.
    Essentially, you create named views in the drawing where the note, detail, or whatever lives.
    Then you reference that view with a callout block in the other drawing.
    Kate does a much better job explaining here with video here: http://www.youtube.com/watch?v=DJyfwJXdK2M
    R.K. McSwain | CAD Panacea |
  1. Note Blocks and Note Symbols
    By jyount in forum Revit Architecture - General
    Last Post: 2006-12-06, 02:29 PM
  2. Match line call outs as fields - link fields across sheets
    By david_ellis in forum AutoCAD Fields
    Last Post: 2006-06-13, 09:49 PM
  3. has anyone had any luck with fields and revision date & note?
    By ALopez.75899 in forum AutoCAD Fields
    Last Post: 2004-12-21, 06:47 PM
