Results 1 to 10 of 11
Thread: Object Position in Field
    Default Object Position in Field
    I am trying to create a field that creates an XYZ in a block.
    I have tried to select the block, but I don’t see position as an option to choose in the object field.
    Any ideas how to create a block that auto-updates the XYZ coords when you move it?
    Default Re: Object Position in Field
    Anyone?
    Seems simple enough…attach XYZ values to a block.
    Thoughts?
    2010-10
    Việt Nam
    45
    You can create a field out of Block def, link to Position of Block, and group them together
    Sounds great…can you give me a bit deeper of instruction. A bit of a Newbie. Thanks
    2010-10
    Việt Nam
    45
    Cool Re: Object Position in Field
    Here i post 2 solution.
    One as i mentioned above, use a field outside Block definition and group all together
    Other use BlockPlaceHolder and Attribute inside Block Def. Have fun
    Block Place.dwg
    Thanks. Question, how do you get the xyz Coords to update once you move the block around? Regen doesn’t seem to do it.
    Cairo - no, not Illinois
    5,070
    What is FIELDEVAL set to?
    I type in FIELDEVEL and I believe it is currently set at 31?
    5,070
    31 should work -- and the example is updating here w/ no problem.
    You did explode the container drawing, right?
    I simply moved your block in the drawing and did a regen…saw no results. What do I need to explode?
    PS…thanks for the hand-holding!
  1. Replies: 16
    Last Post: 2008-10-21, 05:35 AM
  2. Calculating Y Position Within a Field in ACA 2008.
    By rdaniel in forum ACA General
    Last Post: 2008-03-13, 11:22 PM
  3. Field Grid Position
    By wpeacock in forum AutoCAD Fields
    Last Post: 2007-09-08, 10:06 AM
  4. Dynamic Block Position X,Y Field
    By CADdancer in forum Dynamic Blocks - Technical
    Last Post: 2007-08-31, 04:58 PM
  5. Replies: 13
    Last Post: 2007-03-09, 07:53 AM
