Results 1 to 10 of 11
Thread: Folder Browser Dialog for LISP
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,125
    Default Folder Browser Dialog for LISP
    Hey Group,
    One function that is exposed in the shell.application is browseforfolder.
    ; LISP syntax (browseforfolder "Select Folder" "C:\\acad")
    (defun BrowseForFolder (strMessage
                             strRootFolder
                             lstObjects
                             objShellApp
                             objFolder
                             objParentFolder
                             strPath
     (and
      (setq objShellApp (vla-getInterfaceObject
                         (vlax-get-acad-object)
                         "Shell.Application"
      (setq lstObjects (list objShellApp))
      (setq objFolder   (vlax-invoke objShellApp
                                    'BrowseForFolder
                                    strMessage
                                    strRootFolder
      (setq lstObjects (cons objFolder lstObjects))
      (setq strTitle          (vlax-get    objFolder       "Title"))
      (setq objParentFolder   (vlax-get    objFolder       'ParentFolder))
      (setq lstObjects (cons objParentFolder lstObjects))
      (setq strPath (vlax-get (vlax-invoke objParentFolder "Parsename" strTitle) "Path"))
     (mapcar 'vlax-release-object lstObjects)
     strPath
    But it does not allow you to pre select a selectedfolder.
    .NET has a browsefolderdialog that gives you more options including the ability to selectfolder.
    See next post.
    AutomateCAD
    2000-09
    Honolulu HI
    1,125
    Default Re: Folder Browser Dialog for LISP
    This is the code.
    It has several options for the lisp function and you may want to modify it to add maybe the root folder etc...
    You can view its functionality on Youtube to see if is something you like.
    http://www.youtube.com/watch?v=Ug0k5...ature=youtu.be
    Imports Autodesk.AutoCAD.Runtime
    Imports Autodesk.AutoCAD.DatabaseServices
    Imports System.Windows.Forms
    ''' <summary>
    ''' Folder Class to create a LISP Function to display the Folder Browser Dialog
    ''' In the System.Windows.Forms Class
    ''' </summary>
    Public Class FolderClass
        ''' <summary>
        ''' LISP Function to display the Folder Browser Dialog
        ''' </summary>
        ''' <param name="rbfArguments"></param>
        ''' <remarks>LISP Syntax
        ''' (folder)                           Default Selected Path is C:\\
        ''' (folder "C:\\")                    Sets the Selected Path to C:\\
        ''' (folder "C:\\" "Select Folder")    Sets Description to "Select Folder"
        ''' (folder "C:\\" "Select Folder" T)  Displays New Folder Button
        ''' </remarks>
        <LispFunction("Folder")> _
        Public Function Folder(ByVal rbfArguments As ResultBuffer)
            Try
                If rbfArguments Is Nothing Then Return Folder("C:\")
                Dim arrArguments As TypedValue() = rbfArguments.AsArray()
                Select Case arrArguments.Length
                    Case 0
                    Case 1
                        Return Folder(arrArguments(0).Value.ToString)
                    Case 2
                        Return Folder(arrArguments(0).Value.ToString, arrArguments(1).Value.ToString)
                    Case 3
                        Return Folder(arrArguments(0).Value.ToString, arrArguments(1).Value.ToString, True)
                End Select
            Catch ex As System.Exception
            End Try
            Return Nothing
        End Function
        ''' <summary>
        ''' .NET Function to display Folder Browser Dialog
        ''' </summary>
        ''' <param name="strSelectedPath"></param>
        ''' <param name="strDescription"></param>
        ''' <param name="blnNewFolderShow"></param>
        ''' <returns>Selected folder as string</returns>
        Public Function Folder(Optional ByVal strSelectedPath As String = "", _
                               Optional ByVal strDescription As String = "", _
                               Optional ByVal blnNewFolderShow As Boolean = False)
            Try
                If strSelectedPath IsNot Nothing Then
                    Dim folderBrowserDialog As New FolderBrowserDialog
                    folderBrowserDialog.RootFolder = Environment.SpecialFolder.MyComputer
                    folderBrowserDialog.SelectedPath = strSelectedPath
                    folderBrowserDialog.Description = strDescription
                    folderBrowserDialog.ShowNewFolderButton = blnNewFolderShow
                    folderBrowserDialog.ShowDialog()
                    Return folderBrowserDialog.SelectedPath
                End If
            End Try
            Return Nothing
        End Function
    End Class
    AutomateCAD
    Earth
    9,828
    Quote Originally Posted by peter View Post
    Hey Group,
    Very nice. Thanks.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,743
    Hey Group,
    I too am a fan of BrowseForFolder... My old BatchFindSurface routine for Civil 3D comes to mind for this specific topic, and includes some other goodies.
    Cheers
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2009-11
    5,743
    BTW, Shell.Application (an external object) is never released.
    Computer Specs:
    2009-11
    5,743
    Here's a slightly different adaptation of the LISP code posted above that may prove useful... Please note the allowed parameter combinations shown in the commented examples:
    (vl-load-com)
    (defun _BrowseForFolder	(msg path / *error* acApp oShell oFolder)
      ;; Examples:
      ;; (_BrowseForFolder "Select a Folder" nil)
      ;; (_BrowseForFolder nil nil)
      ;; (_BrowseForFolder nil "C:\\users")
      (defun *error* (msg)
        (if	oShell (vlax-release-object oShell))
        (cond ((not msg))							; Normal exit
    	  ((member msg '("Function cancelled" "quit / exit abort")))	; <esc> or (quit)
    	  ((princ (strcat "\n** Error: " msg " ** ")))			; Fatal error, display it
        (if	oFolder path nil)
      (and
        (or
          (and (= 'STR (type path)) (findfile path))
          (setq path (+ 1 64 256))
        (or (= 'STR (type msg)) (setq msg "Select a Folder to Search"))
        (setq acApp (vlax-get-acad-object))
        (setq oShell (vla-getinterfaceobject acApp "Shell.Application"))
        (setq oFolder
    	   (vlax-invoke
    	     oShell
    	     'BrowseForFolder
    	     (vla-get-hwnd acApp)
    	     msg
    	     path
        (setq path (vlax-get-property
    		 (vlax-get-property oFolder 'Self)
    		 'Path
      (*error* nil)
    Computer Specs:
    2000-09
    Honolulu HI
    1,125
    Quote Originally Posted by BlackBox View Post
    I have thought about that, in my original code I had the release expressions, but when I checked, because of the localized variable, LISP releases it automatically.
    I could never find any documentation on whether the release statement is or is not required for a localized variable.
    Do you know of any?
    Peter
    AutomateCAD
    2009-11
    5,743
    As I understand it.... While localisation clears the variable (symbol) value from being accessed once the Defun's scope has ended, this unfortunately does not account for releasing the object instance itself, which could result in multiple instances lingering for repeated code, and can cause other application, or even OS issues down the line.
    This principle applies to any external object, be it an AutoCAD-based object like the legacy Land Desktop (external) Database, today's Civil 3D COM Objects, or Shell.Application Object, Scripting.FileSystemObject Object, and ADsSecurityUtility Object, etc. as some other examples.
    Do you know of any?
    Especially if you're using 2012-2013 the ActiveX documentation is a bit cumbersome to use, IMO. 2014 is a little better, but you may want to install the offline help depending on bandwidth limitation, etc.
    Straight from the ActiveX Developer Documentation within VLIDE:
    vlax-Release-Object
    When an AutoLISP routine no longer uses an object outside AutoCAD, such as a Microsoft Excel object, call the (vlax-release-object) function to make sure that the associated application closes properly. Objects released with (vlax-release-object...) may not be released immediately. The actual release may not happen until the next automatic garbage collection occurs.
    HTH
    Computer Specs:
    2000-09
    Honolulu HI
    1,125
    I added them back into the example at the top.
    Although the thread was more about how to do that with .net and not with the shell application.
    p=
    AutomateCAD
    2009-11
    5,743
    What happens in the event of an error?
    Fair enough; here's an alternative that provides some native 'invalid argument' handling:
    using Autodesk.AutoCAD.ApplicationServices;
    using Autodesk.AutoCAD.DatabaseServices;
    using Autodesk.AutoCAD.Runtime;
    using acApp = Autodesk.AutoCAD.ApplicationServices.Application;
    using System;
    using System.IO;
    using System.Windows.Forms;
    [assembly: CommandClass(typeof(BlackBox.AutoCAD.FolderBrowser.Commands))]
    namespace BlackBox.AutoCAD.FolderBrowser
        public class Commands
            private bool showNewFolderButton;
            private DocumentCollection acDocs = acApp.DocumentManager;
            private string selectedPath;
            private string description;
            private object Browse()
                FolderBrowserDialog folderBrowserDialog = new FolderBrowserDialog();
                folderBrowserDialog.Description = description;
                folderBrowserDialog.RootFolder = Environment.SpecialFolder.MyComputer;
                folderBrowserDialog.SelectedPath = selectedPath;
                folderBrowserDialog.ShowNewFolderButton = showNewFolderButton;
                if (folderBrowserDialog.ShowDialog() != DialogResult.OK)
                    return null;
                return folderBrowserDialog.SelectedPath;
            [LispFunction("FolderBrowser")]
            public object FolderBrowser(ResultBuffer resbuf)
                showNewFolderButton = false;
                selectedPath = "C:\\";
                description = "";
                try
                    if (resbuf == null)
                        return Browse();
                    TypedValue[] args = resbuf.AsArray();
                    int i = args.Length;
                    if (args[0].TypeCode != (int)LispDataType.Text)
                        throw new ArgumentTypeException("stringp", args[0]);
                    selectedPath = (string)args[0].Value;
                    if (!Directory.Exists(selectedPath))
                        throw new DirectoryDoesNotExistException();
                    if (i >= 2)
                        if (args[1].TypeCode != (int)LispDataType.Text)
                            throw new ArgumentTypeException("stringp", args[1]);
                        description = (string)args[1].Value;
                    if (i == 3 && args[2].TypeCode != (int)LispDataType.Nil)
                        showNewFolderButton = true;
                    return Browse();
                catch (LispException ex)
                    acDocs.MdiActiveDocument.Editor.WriteMessage(
                        "\n; error: LispException: " + ex.Message + "\n");
                    return null;
                catch (System.Exception ex)
                        "\n; error: System.Exception: " + ex.Message + "\n");
                    return null;
        /// <summary>
        /// Special thanks to Gile for his LispException classes:
        /// </summary>
        class LispException : System.Exception
            public LispException(string msg) : base(msg) { }
        class TooFewArgsException : LispException
            public TooFewArgsException() : base("too few arguments") { }
        class TooManyArgsException : LispException
            public TooManyArgsException() : base("too many arguments") { }
        class ArgumentTypeException : LispException
            public ArgumentTypeException(string s, TypedValue tv)
                : base(string.Format(
               "invalid argument type: {0}: {1}",
               s, tv.TypeCode == (int)LispDataType.Nil ? "nil" : tv.Value))
        // Added by BlackBox
        class DirectoryDoesNotExistException : LispException
            public DirectoryDoesNotExistException() : base("directory does not exist") { }
    Cheers
    Computer Specs:
  1. File Multi Selection Dialog (and Folder Select)
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-02-18, 04:46 PM
  2. 2013: New Folder from dialog
    By dgodfather in forum AutoCAD LT - General
    Last Post: 2013-01-16, 09:39 PM
  3. allow floating origin folder in the browser bar
    Last Post: 2011-11-18, 10:05 AM
  4. Folder Dialog Option
    By bdthomas02 in forum VBA/COM Interop
    Last Post: 2008-07-22, 07:44 PM
  5. Open File Dialog Folder Addition
    By barathd in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-02-07, 04:44 PM
