Results 1 to 8 of 8
Thread: Help with Code loop
    2012-07
    Chattanooga
    9
    Default Help with Code loop
    Hello,
    My knowledge of lisp is nothing...so.
    If it's possible, is anyone willing to show me a way to shorten this code with a loop?
    Any help appreciated, Thanks.
     (defun c:EAB()
    (setq newfile111(getstring "\nFile name to open in z:\\AB\\xxx\\AB"))
    (setq newfile111(strcat "z:\\AB\\xxx\\AB" newfile111))
    ;(command "qsave")
    (SETVAR "FILEDIA" 0)
    (SETQ FILE31 (FINDFILE (STRCAT NEWFILE111 "A" ".15" ".DWG")))
    (SETQ FILE30 (FINDFILE (STRCAT NEWFILE111 "P" ".15" ".DWG")))
    (SETQ FILE29 (FINDFILE (STRCAT NEWFILE111 "A" ".14" ".DWG")))
    (SETQ FILE28 (FINDFILE (STRCAT NEWFILE111 "P" ".14" ".DWG")))
    (SETQ FILE27 (FINDFILE (STRCAT NEWFILE111 "A" ".13" ".DWG")))
    (SETQ FILE26 (FINDFILE (STRCAT NEWFILE111 "P" ".13" ".DWG")))
    (SETQ FILE25 (FINDFILE (STRCAT NEWFILE111 "A" ".12" ".DWG")))
    (SETQ FILE24 (FINDFILE (STRCAT NEWFILE111 "P" ".12" ".DWG")))
    (SETQ FILE23 (FINDFILE (STRCAT NEWFILE111 "A" ".11" ".DWG")))
    (SETQ FILE22 (FINDFILE (STRCAT NEWFILE111 "P" ".11" ".DWG")))
    (SETQ FILE21 (FINDFILE (STRCAT NEWFILE111 "A" ".10" ".DWG")))
    (SETQ FILE20 (FINDFILE (STRCAT NEWFILE111 "P" ".10" ".DWG")))
    (SETQ FILE19 (FINDFILE (STRCAT NEWFILE111 "A" ".09" ".DWG")))
    (SETQ FILE18 (FINDFILE (STRCAT NEWFILE111 "P" ".09" ".DWG")))
    (SETQ FILE17 (FINDFILE (STRCAT NEWFILE111 "A" ".08" ".DWG")))
    (SETQ FILE16 (FINDFILE (STRCAT NEWFILE111 "P" ".08" ".DWG")))
    (SETQ FILE15 (FINDFILE (STRCAT NEWFILE111 "A" ".07" ".DWG")))
    (SETQ FILE14 (FINDFILE (STRCAT NEWFILE111 "P" ".07" ".DWG")))
    (SETQ FILE13 (FINDFILE (STRCAT NEWFILE111 "A" ".06" ".DWG")))
    (SETQ FILE12 (FINDFILE (STRCAT NEWFILE111 "P" ".06" ".DWG")))
    (SETQ FILE11 (FINDFILE (STRCAT NEWFILE111 "A" ".05" ".DWG")))
    (SETQ FILE10 (FINDFILE (STRCAT NEWFILE111 "P" ".05" ".DWG")))
    (SETQ FILE09 (FINDFILE (STRCAT NEWFILE111 "A" ".04" ".DWG")))
    (SETQ FILE08 (FINDFILE (STRCAT NEWFILE111 "P" ".04" ".DWG")))
    (SETQ FILE07 (FINDFILE (STRCAT NEWFILE111 "A" ".03" ".DWG")))
    (SETQ FILE06 (FINDFILE (STRCAT NEWFILE111 "P" ".03" ".DWG")))
    (SETQ FILE05 (FINDFILE (STRCAT NEWFILE111 "A" ".02" ".DWG")))
    (SETQ FILE04 (FINDFILE (STRCAT NEWFILE111 "P" ".02" ".DWG")))
    (SETQ FILE03 (FINDFILE (STRCAT NEWFILE111 "A" ".01" ".DWG")))
    (SETQ FILE02 (FINDFILE (STRCAT NEWFILE111 "P" ".01" ".DWG")))
    (SETQ FILE01 (FINDFILE (STRCAT NEWFILE111 "A" ".00" ".DWG")))
    (SETQ FILE00 (FINDFILE (STRCAT NEWFILE111 "P" ".00" ".DWG")))
    (SETQ FILE (FINDFILE (STRCAT NEWFILE111 "" ".DWG")))
    (IF (/= FILE31 NIL)
    (PROGN
      (SETQ newfile111 FILE31)
      (command "vbastmt" (strcat "AcadApplication.Documents.Open " "\"" newfile111 "\""))
      (QUIT)))
    (IF (/= FILE30 NIL)
    (PROGN
      (SETQ newfile111 FILE30)
      (QUIT)))
    (IF (/= FILE29 NIL)
    (PROGN
      (SETQ newfile111 FILE29)
      (QUIT)))
    (IF (/= FILE28 NIL)
    (PROGN
      (SETQ newfile111 FILE28)
      (QUIT)))
    (IF (/= FILE27 NIL)
    (PROGN
      (SETQ newfile111 FILE27)
      (QUIT)))
    (IF (/= FILE26 NIL)
    (PROGN
      (SETQ newfile111 FILE26)
      (QUIT)))
    (IF (/= FILE25 NIL)
    (PROGN
      (SETQ newfile111 FILE25)
      (QUIT)))
    (IF (/= FILE24 NIL)
    (PROGN
      (SETQ newfile111 FILE24)
      (QUIT)))
    (IF (/= FILE23 NIL)
    (PROGN
      (SETQ newfile111 FILE23)
      (QUIT)))
    (IF (/= FILE22 NIL)
    (PROGN
      (SETQ newfile111 FILE22)
      (QUIT)))
    (IF (/= FILE21 NIL)
    (PROGN
      (SETQ newfile111 FILE21)
      (QUIT)))
    (IF (/= FILE20 NIL)
    (PROGN
      (SETQ newfile111 FILE20)
      (QUIT)))
    (IF (/= FILE19 NIL)
    (PROGN
      (SETQ newfile111 FILE19)
      (QUIT)))
    (IF (/= FILE18 NIL)
    (PROGN
      (SETQ newfile111 FILE18)
      (QUIT)))
    (IF (/= FILE17 NIL)
    (PROGN
      (SETQ newfile111 FILE17)
      (QUIT)))
    (IF (/= FILE16 NIL)
    (PROGN
      (SETQ newfile111 FILE16)
      (QUIT)))
    (IF (/= FILE15 NIL)
    (PROGN
      (SETQ newfile111 FILE15)
      (QUIT)))
    (IF (/= FILE14 NIL)
    (PROGN
      (SETQ newfile111 FILE14)
      (QUIT)))
    (IF (/= FILE13 NIL)
    (PROGN
      (SETQ newfile111 FILE13)
      (QUIT)))
    (IF (/= FILE12 NIL)
    (PROGN
      (SETQ newfile111 FILE12)
      (QUIT)))
    (IF (/= FILE11 NIL)
    (PROGN
      (SETQ newfile111 FILE11)
      (QUIT)))
    (IF (/= FILE10 NIL)
    (PROGN
      (SETQ newfile111 FILE10)
      (QUIT)))
    (IF (/= FILE09 NIL)
    (PROGN
      (SETQ newfile111 FILE09)
      (QUIT)))
    (IF (/= FILE08 NIL)
    (PROGN
      (SETQ newfile111 FILE08)
      (QUIT)))
    (IF (/= FILE07 NIL)
    (PROGN
      (SETQ newfile111 FILE07)
      (QUIT)))
    (IF (/= FILE06 NIL)
    (PROGN
      (SETQ newfile111 FILE06)
      (QUIT)))
    (IF (/= FILE05 NIL)
    (PROGN
      (SETQ newfile111 FILE05)
      (QUIT)))
    (IF (/= FILE04 NIL)
    (PROGN
      (SETQ newfile111 FILE04)
      (QUIT)))
    (IF (/= FILE03 NIL)
    (PROGN
      (SETQ newfile111 FILE03)
      (QUIT)))
    (IF (/= FILE02 NIL)
    (PROGN
      (SETQ newfile111 FILE02)
      (QUIT)))
    (IF (/= FILE01 NIL)
    (PROGN
      (SETQ newfile111 FILE01)
      (QUIT)))
    (IF (/= FILE00 NIL)
    (PROGN
      (SETQ newfile111 FILE00)
      (QUIT)))
    (IF (/= FILE NIL)
    (PROGN
      (SETQ newfile111 FILE)
      (QUIT)))
    (SETQ DIALOG_FILE (getfiled "AB DRAWINGS" newfile111 "DWG" 4))
    ;(SETQ DIALOG_FILE (STRCAT "z:\\AB\\xxx\\"  DIALOG_FILE))
      (command "vbastmt" (strcat "AcadApplication.Documents.Open " "\"" DIALOG_FILE "\""))
    );END OF FUNCTION EAB
    2015-10
    Belgrade, Serbia, Europe
    564
    2
    Default Re: Help with Code loop
    Hi, I've changed variable names according to my (while) looping, but the action of routine is the same... Try it, not tested though...
    (defun c:EAB ( / *error* newfile111 k FILE DIALOG_FILE )
      (defun *error* ( msg / k )
        (setq k 16)
        (while (> (setq k (1- k)) -1)
          (set (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "A")) nil)
          (set (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "P")) nil)
        (if msg (prompt msg))
        (princ)
      (setq newfile111 (getstring "\nFile name to open in z:\\AB\\xxx\\AB\\ : "))
      (setq newfile111 (strcat "z:\\AB\\xxx\\AB\\" newfile111))
      (setvar 'FILEDIA 0)
      (setq k 16)
        (set (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "A")) (findfile (strcat newfile111 "A" "." (if (> k 9) (itoa k) (strcat "0" (itoa k))) ".DWG")))
        (set (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "P")) (findfile (strcat newfile111 "P" "." (if (> k 9) (itoa k) (strcat "0" (itoa k))) ".DWG")))
      (setq FILE (findfile (strcat newfile111 "" ".DWG")))
      (setq k 16)
        (if (/= (eval (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "A"))) nil)
          (progn
            (setq newfile111 (eval (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "A"))))
            (quit)
        (if (/= (eval (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "P"))) nil)
          (progn
            (setq newfile111 (eval (read (strcat "FILE" (if (> k 9) (itoa k) (strcat "0" (itoa k))) "P"))))
            (quit)
      (if (/= FILE nil)
        (progn
          (setq newfile111 FILE)
          (quit)
      (setq DIALOG_FILE (getfiled "AB DRAWINGS" newfile111 "DWG" 4))
      (princ)
    HTH, M.R.
    Ontario, Canada
    116
    2
    A (very slightly) different approach. No error handling, and untested.
    (defun c:foo ( / AP CTR DOCUMENTS NEWDOC NEWFILE NEWFILE111)
      (setq documents (vlax-get-property (vlax-get-acad-object) 'documents)
    	newfile (strcat "z:\\AB\\xxx\\AB" (getstring "\nFile name to open in z:\\AB\\xxx\\AB"))
    	ap (list "A" "P")
    	ctr 31
    	); setq
      (while (and (not (minusp ctr))
    	      (null (setq newfile111 (findfile (strcat newfile (nth (rem ctr 2) ap) "." (itoa (/ ctr 2)) ".dwg"))))
    	      ); and
        (setq ctr (1- ctr))
        ); while
      (if newfile111
        (progn
          (setq newdoc (vlax-invoke documents 'open newfile111))
          (vlax-invoke newdoc 'activate)
          ); progn
        (prompt "\nCannot find file. ")
        ); if
      ); setq
    Last edited by GHarvey; 2014-02-13 at 02:06 PM. Reason: Noticed some errors in code
    Ontario, Canada
    116
    Sorry, just noticed a few problems with the code above. Will correct shortly...
    Edit: Alright, that should do it... I hope.
    2012-07
    Chattanooga
    9
    Thanks, guys.
    2012-07
    Chattanooga
    9
    Thanks again for your help.
    I wound up with the following code.
    (defun c:EDB (/ CTR DOCUMENTS NEWDOC NEWFILE NEWFILE111 num)
    	newfile	  (strcat "Z:\\DB\\XXX\\DB"(getstring "\nFile name to open in Z:\\DB\XXX\\DB"))
    	ctr	  30
    	) ; setq
      (while (not (minusp ctr))
        (if	(= 2 (strlen (itoa ctr)))
          (setq num (itoa ctr)) ; "Yes! Then"
          (setq num (strcat "0" (itoa ctr))) ; "No! Else"
          ) ;if
        (setq dwg (strcat newfile "P." num ".dwg"))
        (if	(findfile dwg)
          (setq newfile111 dwg)
          (setq dwg (strcat newfile "A." num ".dwg"))
        (if (findfile dwg)
        (setq ctr (1- ctr))
        ) ; while
      (if newfile111
        (progn
          (quit)
          ) ; progn
        ) ; if
      )  ; setq
    2012-07
    Chattanooga
    9
    Well, after further review....
    (defun c:FDB (/  CTR DOCUMENTS NEWDOC NEWFILE NEWFILE111 num)
    	ctr 30
    	) ; setq
      (if (while (not (minusp ctr))
    	  ) ;if
    	(if (findfile dwg)
    	(if (findfile dwg)
    	(if newfile111
    	  (progn (command "vbastmt" (strcat "AcadApplication.Documents.Open ""\"" newfile111 "\""))
    		 (quit)
    		 ) ; progn
    	  ) ; if
    	(setq ctr (1- ctr))
    	) ; while
        ) ; if
      )  ; setq
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,135
    Does this do what you need it to do? Will there only ever be 15 numbers? Will there only be an "A" or "P" named files in the directory?
    Why not get a list of the files in the directory that match your filename prefix? You can quickly get that with the vl-directory-files function.
    (defun GetAvailableFiles (directory prefix code extension / FileList)
      ; Returns a list of filenames found in the directory.
      ; Required variables
      ; directory is a string containing the directory path
      ; prefix is the filename prefix as supplied by the user
      ; code is a list of codes
      ; extension is the file extension and should be prefixed with a "."
      (foreach n code
        (setq FileList (append FileList
    			   (vl-directory-files
    			     directory
    			     (strcat prefix code ".??" extension)
    You could then assign the returned value to a variable and then cycle through the list to open each file.
    (defun c:FDB (/ directory prefix code extension AvailableFiles documents newdoc)
      (setq	directory      "Z:\\DB\\XXX\\DB"
    	prefix	       (getstring
    			 (strcat "\nFile name to open in <" directory ">: ")
    	code	       '("A" "P")
    	extension      ".dwg"
    	AvailableFiles (GetAvailableFiles directory prefix code extension)
      (if AvailableFiles
        (progn
          (setq documents
          (foreach n AvailableFiles
    	(setq newdoc
    	       (vlax-invoke documents 'Open (strcat directory "\\" n))
    	(vlax-invoke newdoc 'Activate)
          (vlax-release-object newdoc)
          (vlax-release-object documents)
  1. how do i loop this?
    By mgonzales.224492 in forum AutoLISP
    Last Post: 2009-07-31, 06:41 PM
  2. Insert vbscript code has not code
    By buzz in forum AMEP General
    Last Post: 2008-02-09, 03:08 AM
  3. Block Insert Array (Loop within a Loop)
    By wpeacock in forum VBA/COM Interop
    Last Post: 2005-06-14, 04:24 AM
