Results 1 to 6 of 6
Thread: Slab edge projected lines turn invisible in sketch mode
    2004-06
    Memphis TN area
    7,047
    Default Slab edge projected lines turn invisible in sketch mode
    On our site plans we use slab edge sweeps for things like curbs, curb and gutter, etc. The problem is that when in sketch mode editing a topo, or a floor, the projected edge lines of the slab edge sweeps turn invisible, while everything else is halftone. When I pan or zoom, hatch patterns disappear, but the slab edge projected lines appear. After I finish panning or zooming, the hatch patterns come back, but the slab edge lines disappear again. Makes it difficult to place topo points along or near those edges.
    Is it some graphic setting maybe?
    AERC, PLLC
    Hernando, Mississippi
    Default Re: Slab edge projected lines turn invisible in sketch mode
    Not that many experience with topo's myself, but I do come across this when editting floors/roofs with sub elements... When things start to disappear in editing mode, just draw some detail lines over the lines you're interested in, these stay visible all the time... I know it's not a real sollution, but it does work.
    Hmm... does this post do show up?
    2003-03
    Philadelphia, PA
    2,387
    Quote Originally Posted by matthijs_frederiks View Post
    It does now, as does your original post. Welcome to the AUGI Forums and thanks for your participation. To prevent spammers from creating new accounts and then flooding the forums with spam, posts by members with low post counts are automatically put in the moderation queue. Once you have a few more posts under your belt, you should see them appear as you post them.
    David Koch
    2005-07
    Somewhere in the BIM world
    3,792
    Are you using 2014?
    There's a new settings called Optimized View Navigation. That would explain the texture being turn off when you move around.
    As for the lines not visible, check if the line category is turn on and if its within the View Range.
    2004-06
    Memphis TN area
    7,047
    I tried changing the Optimized Navigation setting, but that had no effect on the slab edge projected lines disappearing while in sketch mode. It seems odd that they would appear while panning or zooming, so it's definitely not the category being turned off.
    AERC, PLLC
  1. Auto clean-up of sketch lines in sketch mode (families, floors, roofs, ceilings etc)
    Last Post: 2014-10-22, 10:53 PM
  2. Paste Lines from e.g. Autocad into Revit Sketch mode (Family Creation, Masses etc.)
    Last Post: 2012-12-13, 01:55 AM
  3. projected sketch origin lines get bigger as sketch is drawn
    Last Post: 2012-02-09, 09:44 AM
  4. how to hide slab edge lines in section
    By jcapp in forum Revit Structure - General
    Last Post: 2010-09-14, 02:05 PM
  5. Pick Toposurface edge lines when in pad sketch mode
    By robmorfin in forum Revit Architecture - Wish List
    Last Post: 2004-04-08, 12:35 AM
