Thread: Can't load PDF file into Autocad 2014
    2015-09
    72
    Question Can't load PDF file into Autocad 2014
    Hello,
    We recently upgrade to AutoCAD2014 and Acrobat 10
    When I tried to insert a PDF, I get a error message of "This file cannot be opened" and a list of causes.
    The file loads fine in 2011. The funny part is, I would get the same message if I tried to load on a pdf I created with 2014.
    Any suggestion on how I can resolve this problem
    Thanks
    Earth
    9,805
    Default Re: Can't load PDF file into Autocad 2014
    Are you talking about attaching a PDF as a reference to a DWG file?
    Can you attach other PDF's, just not those made with Acrobat 10?
    R.K. McSwain | CAD Panacea |
    2015-09
    72
    Yes, I usally attach as a ref when I don't have CAD files
    I have tried different versions of acrobat PDF and they didn't load
    I might try and reload Acrobat again. it was loaded before Autocad
  1. 2014: AutoCAD 2014, File with image will not print.
    By JohnnyCicc in forum AutoCAD General
    Last Post: 2014-11-20, 12:59 PM
  2. 2014: Autocad 2014: file names on the file tabs are missing!
    By mephasm in forum AutoCAD General
    Last Post: 2013-04-29, 07:20 AM
  3. My mnl file will not load in AutoCAD 2010
    By ken.ferguson in forum AutoCAD Customization
    Last Post: 2009-08-07, 12:19 PM
  4. autocad won't load main cui file
    By cwjean76 in forum AutoCAD General
    Last Post: 2009-03-10, 09:57 PM
  5. Replies: 2
    Last Post: 2006-10-25, 09:10 PM
