Thread: dynamic block stretch not working properly
    2013-10
    6
    Default dynamic block stretch not working properly
    attached dynamic block is designed to stay centered on its insertion point, While if you stretch it, the left and right sides should go out an equal distance(which they do).
    Problem is in that the dimension line comes unstuck from the left location point once stretched, such that if you are using dynamic input and input say 350 as the stretch distance it may go out to aproximatly 500.
    Any suggestions on how to get the left dimension line to stay stuck on its correct point.
    Thanking any help.
    2007-06
    Flagstaff, AZ
    264
    Default Re: dynamic block stretch not working properly
    Open the block in block editor, select the linear parameter, go to properties, find base location and switch it from Startpoint to Midpoint.
    2013-10
    6
    Thanks libbybapa,
    the result is much better.
  1. Get Attributes to Stretch in a Dynamic Block
    By CADdancer in forum Dynamic Blocks - Technical
    Last Post: 2015-02-05, 07:20 PM
  2. Dynamic block Stretch
    By wjo53377274 in forum Dynamic Blocks - Technical
    Last Post: 2013-08-09, 08:59 PM
  3. 2013: Help With Dynamic Block Stretch Action
    Last Post: 2013-04-18, 07:33 PM
  4. Trying to Stretch a hatch in a Dynamic Block with the Stretch parameter
    By hnewman in forum Dynamic Blocks - Technical
    Last Post: 2007-11-05, 09:34 PM
  5. Polar stretch and Array not working properly with Dynamic Block
    By r424andy in forum Dynamic Blocks - Technical
    Last Post: 2006-12-20, 04:31 PM
