I am using Civil 3d 2014 and I want to create a points list for use in a stakeout of the centerline alignment. I would like to know if there is a way to have Civil just place a survey point at each P.I. and to just use the alignment station value for the description and the existing surface elevation for the elevation. I know you can use the pull down <Points- Create Points - Alignments - At Geometry points> will work. However it will ask for all of the information that I would like to have it populate automatically. I just want to know if there is a way to configure the command to do it all for me.
Any help would be great.
