Results 1 to 10 of 11
Thread: STARTUP SUITE PROBLEMS
    2013-03
    Permian Basin
    76
    Default STARTUP SUITE PROBLEMS
    I have a routine that will copy the .dwg file name and put it into my title block under the title. It works perfectly except I can't get it to load into my startup suite. If I want the code to run I have to manually load it each time I want to use it. My company protects the acadloc.lsp file so I cant load it into there. Is there a way I can manipulate the code to make it run under the startup suite?
    (defun c:cdn ()
    (setq name (getvar "dwgname"))
    (setq nm1 (substr name 1 (-(strlen name)4) ))
    (defun Glblattchg (bn Tg Tv / aDoc ss)
      (vl-load-com)
      (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
      (cond
        ((and
           (ssget
             "_x"
             (list '(0 . "INSERT") (cons 2 (strcat bn ",`*U*")))
           (vlax-for
              itm (setq ss (vla-get-ActiveSelectionSet aDoc))
             (if (and
                   (eq (strcase (vla-get-EffectiveName itm)) (strcase bn))
                   (setq itm (assoc
                     (strcase tg)
                     (mapcar
                       (function
                         (lambda (j)
                           (list
                             (vla-get-tagstring j)
                             (vla-get-textstring j)
                             j
                       (vlax-invoke itm 'GetAttributes)
                   )(vla-put-textstring (last itm) tv)
           (vla-delete ss)
    (GLBLATTCHG "2012-BORDER" "DWG_NAME" nm1)
    (princ)
    2005-06
    in the upper right corner
    3,305
    Default Re: STARTUP SUITE PROBLEMS
    Consider using Acaddoc.lsp for loading lisp routines (as well as variables etc), way better than startup suite!!
    Seach AUGI for this topic, I'm sure this will fix your problem.
    ** edit **
    sorry, just read where your acaddoc.lsp is protected.. my bad
    Ted
    ____________________________________________________________________ ________________
    Windows 10
    AutoCAD 2018 - REVIT 2019 - Inventor Professional 2017 (when I can)
    2005-06
    3,305
    Ok, another question, why don't you use a field to automatically place the file name in the title block?
    You wouldn't need the routine at all (as far as I can tell)
    Just curious
    Ted
    Windows 10
    2013-03
    Permian Basin
    76
    I would like to use fields but the client stated that they want no fields in their drawings.
    2009-11
    5,585
    A couple of things....
    I do not use Startup Suite at all, but try adding this to the very bottom of your routine:
    (c:cdn)
    ... You see the code you posted above defines the command, but never calls (invokes) it. Adding this ^^ to the end of the code will do exactly that; call the command each time the routine (the source .lsp file) is loaded.
    Quote Originally Posted by jayhay35365091 View Post
    There's nothing wrong with AcadDoc.lsp being read-only, I did that for years, but I also had the forethought that other users would like to load their own LISP which is why I added something like this:
    Quote Originally Posted by BlackBox View Post
    I also add (load <username>.lsp) functionality with which each user can specify their own variable settings, customizations, etc.. This file is saved in the user's personal network space, which is also included in the Support File Search Paths.
    Example:
    (if (findfile (strcat (setq userName (getvar 'loginname)) ".lsp"))
       (load userName)
    As for modifying the title block, why not just populate that attribute via Field & Sheet Set Manager? All OOTB functionality.
    [Edit] - Just saw your post about client relegation with regard to field use.
    HTH
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2015-12
    2,095
    Some of our clients are running EDMS systems which include DWG viewers which can't process fields. It happens, we just have to live with it and move on.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
    2009-11
    5,585
    Quote Originally Posted by dgorsman View Post
    No worries; makes sense... I may have been a bit harsh.
    Computer Specs:
    Member cwake's Avatar
    2016-01
    4
    These are just some ideas in case they haven't been considered. They may or may not help... it depends on how your company operates.
    From this I assume that using RTEXT in the Title Block with a DIESEL expression isn't acceptable either? It's a simple way to achieve the same thing.
    $(substr,$(getvar,dwgname),1,$(-,$(strlen,$(getvar,dwgname)),4))
    If both your main and enterprise customisation files are not read only, can you add your own "partial customisation file" without changing company setup? Look into what can be done with the "LISP Files" node in the CUI or with ".mnl" files.
    Appload data is stored in your pc's registry. Perhaps the reason it isn't working for you is user account control imposed by your IT department? There are various ways that CAD and IT management can balance enforcing company standards while allowing individual preferences. BlackBox's suggestion in post #5 is a good example. Individual preferences can enhance productivity. Perhaps internal discussions with the management can lead to some aspects being relaxed?
    2009-11
    5,585
    The last alternative that I can come up with, for a user to circumvent any read-only permissions to the built-in files, etc. (in 2012+ versions) is to use the Autoloader mechanism, which is local to user and is implicitly trusted... Autoloader supports LISP, and setting the PerDocument XmlAttribute to "true" will allow any custom LISP routine(s) to be loaded automagically into all documents opened in the editor (similar to AcadDoc.lsp).
    HTH
    Computer Specs:
    2005-06
    3,305
    (c:cdn)
    Both great suggestions!
    Thanks BlackBox, I learned something new today (your second suggestion).. never thought of that before.
    @Jayhay....
    I'm thinking BB's first suggestion will be the quickest and should work for you.
    The second one would require your administrator adding that code to the protected acaddoc.lsp where anyone with a <loginname>.lsp could run their own routines too on thier acad sessions.
    Let us know how it works out for you.
    Ted
    Windows 10
  1. Startup Suite
    By Borgster in forum AutoLISP
    Last Post: 2014-04-24, 04:31 PM
  2. Startup Suite Not Working
    By jchavez76 in forum AutoCAD Customization
    Last Post: 2010-10-08, 12:09 PM
  3. VBA and Startup Suite
    By mboyer in forum VBA/COM Interop
    Last Post: 2007-01-16, 09:26 PM
  4. Startup Suite
    By dmarcotte4 in forum API Wish List
    Last Post: 2006-11-02, 04:19 AM
  5. Startup Suite and Profiles
    By mjsregister in forum VBA/COM Interop
    Last Post: 2004-06-28, 12:06 PM
