Thread: VBA import Text
    2014-01
    16
    Default VBA import Text
    I tried the code for importing the text data This may be someone can help and add text rotation 90" and positioned in the middle left this my code;
    Sub Xxxx()     Dim ACAD As AcadApplication     Dim txObj As acadText     Dim ws As Range     Dim CrdNo(0 To 2) As Double     Dim TxNo As String     Dim hNo As Double     Dim LastRow As Double     Dim i As Integer     Dim j As Integer     Dim k As Integer     Set ACAD = GetObject(, "AutoCAD.Application")     Set ws = Worksheets("NUM").Cells     LastRow = ws(Rows.Count, 20).End(xlUp).Row     hNo = 0.3            For i = 2 To LastRow          j = 20          CrdNo(0) = ws(i, j): CrdNo(1) = ws(i, j + 1): CrdNo(2) = "0"          TxNo = ws(i, j)       Next i       Set txObj = ACAD.ActiveDocument.ModelSpace.AddText(TxNo, CrdNo, hNo)   End Sub
    sorry i has edit my code and then im waiting for your help to rotated text Thanks For Help
    2014-01
    16
    Default Re: VBA import Text
    Sub Xxxx()
         Dim ws As Range
         Dim TxNo As String
         Dim hNo As Double
         Dim i As Integer
         Dim j As Integer
         Dim k As Integer
         hNo = 0.3
              j = 20
              TxNo = ws(i, j)
           Next i
    End Sub
    2012-11
    Italy
    65
    add
    txObj.Rotation = 0.707 '  or whatever angle, in radians, you need. (.707 radians=45 degrees)
    just after
    I'd also suggest you to consider the following
    1) with
    CrdNo(2) = "0"
    you're assigning a string value to a double one.
    maybe you'd rather code
    CrdNo(2) = 0#
    2) with
    TxNo = ws(i, j)
    you're assigning what is supposed to be a double value to a string one.
    if you actually want the text string to reflect the x coordinate than you'd rather code
    TxNo = cstr(ws(i, j))
    3) since j=20 never changes inside the i-loop, you'd better place that line just before starting the loop
    bye
    2014-01
    16
    thankyou very much RICVBA, this code has work now..
    *Thumbs Up*
  1. Import and Export Text to dwg
    By Simon.Whitbread in forum Revit - Platform
    Last Post: 2010-09-23, 02:27 PM
  2. import text file values
    By KHADREE_SHARIFF in forum AutoLISP
    Last Post: 2007-06-25, 08:05 AM
  3. Text Import from Word
    By boofredlay in forum Revit Architecture - General
    Last Post: 2007-01-18, 04:53 PM
  4. DWG Import Detail Text Problems
    By djn in forum Revit Structure - General
    Last Post: 2007-01-15, 12:32 PM
  5. Import text font...
    By gjburkett in forum Revit Architecture - General
    Last Post: 2005-01-27, 10:14 PM
