Thread: Emptye error or warning when closing AutoCAD
    2003-03
    3
    Default Emptye error or warning when closing AutoCAD
    This box shows up twice when I close AutoCAD 2012. I can't find out why or what's causes it.
    Is there a log-file or somewhere where to look? Does any-one else has/had the same problem. What's the solution???
    Cairo - no, not Illinois
    5,070
    Default Re: Emptye error or warning when closing AutoCAD
    not uncommon, and I don't think anyone has identified a cause. You can look into Windows Event Viewer and see if anything pops out at you....
    Solution is hit OK, at least until you can identify the cause.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    Are you using Steltman River Tools? We get the same error on our computers that run Civil 3D with River Tools. It appears to be benign.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Do you have a newer version of AutoCAD also installed on the same computer? That was the cause for me. I no longer have this version installed.
  1. Warning when closing Type Properties window
    Last Post: 2012-07-18, 08:12 AM
  2. Error on closing Autocad
    By aquaman in forum VBA/COM Interop
    Last Post: 2009-01-29, 11:31 AM
  3. Replies: 8
    Last Post: 2007-06-04, 07:01 PM
  4. Closing AutoCAD with project opens causes fatal error
    By bn.srinivasarao in forum VBA/COM Interop
    Last Post: 2006-02-21, 04:26 PM
  5. Closing Autocad fatal error
    By jjacoby in forum AutoCAD General
    Last Post: 2005-06-11, 09:02 PM
Tags for this Thread
