Thread: Annotative text problem
    2004-06
    Slidell, Louisiana
    796
    Default Annotative text problem
    I have a drawing that has annotative text (in model space) at 1:200, 1:300, 1:500 and 1:1000 scales. They all change scale properly while in model space.
    I used design center to import 3 layouts from another dwg that need to be at 1:500. Problem is, when I go to those layouts the text isn't being displayed at the correct scale of 1:500.
    Going into floating model space, some of the text is shown at 1:200 and some at 1:1000. clicking on the text, the dialog shows that the 1:500 scale is on the list, but nothing
    seems to make the text change while in paper or floating model space.
    It only displays correctly in model space.
    Help, please.
    Robert
    All AUGI, all the time Norton_cad's Avatar
    2016-02
    Sydney, Australia
    512
    Default Re: Annotative text problem
    Is the viewport scale set correctly? Command ZOOM S 500XP.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2004-06
    Slidell, Louisiana
    796
    After toying with it for an hour, I finally got it to work. I unlocked the viewport (which came over that way thru design center), then selected the synchronize annotation scale icon which sent the viewport scale to 1:1, then selected the 1:500 scale and voila!!!
    everything was back like it should be.
    Robert
  1. 2011: annotative text and annotative block failure
    By kuruczregina in forum ACA General
    Last Post: 2012-03-25, 06:56 PM
  2. I am having a problem with TEXTMASK and annotative text
    By GreyHippo in forum AutoCAD Annotation
    Last Post: 2010-06-30, 05:32 PM
  3. Annotative block problem
    By Bryan Thatcher in forum ACA General
    Last Post: 2009-06-15, 06:32 PM
  4. Replies: 4
    Last Post: 2007-11-26, 10:22 PM
  5. Annotative text and text count
    By Homerloew in forum AutoCAD Annotation
    Last Post: 2007-10-25, 02:31 AM
