The XREF palette has disappeared. I have used the command showpalettes, but no xref palette. What is the repair for this? or is there a command I am missing that allows you to turn palettes on or off?
What happens when you type in XREF or XR on the command line? Does the palette show?
the XREF palette can be set to collapse. Maybe it's doing that and you can;t see the bar that is there.
