Thread: Quick leader to a block
    2004-08
    19
    Default
    Quick leader to a block. Select quick leader then enter s for settings under annotation select block reference, then when you enter your leader you will be asked for your block reference, type in your reference and you can connect it to your leader.
    chiptagain
    2005-02
    Question Re: Quick leader to a block
    Where on the pull-down menu is this "Quick leader" located or where do you selected it from?
    150700
    3,439
    Default Re: Quick leader to a block
    Pulldown is dimension-->leader
    It is on the dimension toolbar
    command line is qleader (not sure about the alias, as I have edited mine)
    2001-05
    Austin, TX USA
    2,201
    I believe its LE
  1. Multileader vs quick leader with hatch
    By jpduhon in forum AutoCAD Annotation
    Last Post: 2008-03-01, 04:10 AM
  2. Quick Leader & mtext
    By jkramer in forum ACA General
    Last Post: 2007-01-11, 08:16 PM
  3. Replies: 5
    Last Post: 2006-10-11, 01:21 PM
  4. Quick Leader Settings
    By H.Hunter in forum AutoCAD Tips & Tricks
    Last Post: 2006-07-05, 01:59 PM
  5. Quick Leader Gap
    By jfields.61630 in forum AutoCAD General
    Last Post: 2006-03-01, 07:40 PM
