Thread: Can you modify existing functions in C#.
    2014-03
    4
    Default Can you modify existing functions in C#.
    I have just begun to program Revit MEP. I wanted to modify a function for the table pointer for information of the panel schedule.
    I have not been able to find the where I can access the function to modify it. Can this be done? Can I copy the function and rename it for modification?
    Any help with this direction would be great.
    Thanks.
    Turlock, CA
    6,419
    Default Re: Can you modify existing functions in C#.
    .NET only provides an api, not access to the source code. However, depending on what you want to do, you may be able to use an extension method. Do a search for more info on extension methods.
    C:> ED WORKING....
    LinkedIn
    2009-11
    5,719
    ... On the matter of extension methods:
    Quote Originally Posted by BlackBox View Post
    Here's [a] quick example of adding an Extension Method to a native AutoCAD Type (Class).
    HTH
    Computer Specs:
    2014-03
    4
    Thank you. I have trying to get to the source code, now I know I can't. I am trying to produce an electrical panel schedule in a format other than provided. I would like to omit the part of the body (VA columns) and have a document of a specific size with only the number and descriptions of circuits (NO LOADs).
    I think my best bet would be to make a template and populate the cells in that manner.
    I would like this option to be in the revit ribbon, not exported into excel. This being my 4 th partial day learning the API, I want to thank all again, you have saved me a great amount of time trying to get to the source.
    If you have suggestions on how to accomplish this panel schedule goal I am all eye's.
  1. Modify existing surface edits
    Last Post: 2014-11-14, 03:26 PM
  2. Phasing vs. Modelling - Modify existing wall construction
    By 3dway in forum Revit Architecture - General
    Last Post: 2008-07-18, 01:50 AM
  3. modify existing .lsp
    By tomcarver in forum AutoLISP
    Last Post: 2008-06-10, 09:59 PM
  4. modify existing text objects
    By ccowgill in forum AutoLISP
    Last Post: 2005-11-04, 02:35 PM
  5. Replies: 0
    Last Post: 2004-09-18, 04:31 PM
